I disagree, and you’re mixing two arguements.
Acid rain is a naturally occuring event, if you consider the burning of a sulphur containing fuel that creates the inevitable byproduct of one of the various sulphur oxides. Any high school chemistry student can look at sulphur oxides and mix them with water and see that it doesn’t take much juggling to end up with sulphuric acid. This is what happens in the atmosphere. Nature by itself doesn’t put anywhere NEAR as much sulphur into the air as man does. Sure the occasional volcano can spew a lot of sulphur into the air, but when you’re surrounded by fire should you be throwing more gas onto the fire to make it bigger?
Acid rain is real. Lakes have been made sterile by the ph change caused by it. Buildings have been damaged, and people’s health damaged because of it. In the extreme I’ve seen cars damaged by it and the paint peeled off of homes because of it. Out here in the west it has been said that the soil could use a little acid rain, as it’s so alkali. The people and homes how
