Well, these H0 birches( 6-7 inches) are actualy " small parts" of the totaly scenery but could be realy eyecatchers on the right spot:
Jos
Jos
Are those commercial trees or ones you made? What brand or what did you use to make them?
I have some small trees made from local bushes with the yellow leaves. You are right, they standout nicely.
Have fun,
Richard
Eyecatchers? Are you kidding? Eye guess they are! Those are some of the best trees I’ve ever seen! How’d you do that? The pines in the background look fantastic too.
Thanks Richard and " st. Francis etc",
I made the frame , as usualy, with floristic wire. Just like the firtrees in the background.
I make large loops with the wires by twisting the flor.wire first 5-6 times very tight among a "core"wwireand than making a loop ( about 1- 1 1/2 inch)
Again twisting tight 5-8 times around the corewire and making a loop.( the core wire has to be thicker than the ones you use to make the branches…)
Overhere the wires are about 15 inches long so mostly I get 2 loops twisted with one wire.
How many loops you need is up to you…for this birch I used almost 18 loops= about 10- 11 wires.
Plus two you have to twist first as start of the trunk…( = the first two inches of the trunk…)
When loops are made/wire twisted I glue the frame with some drops of cheap superglue and let it dry for some hours.
When dry I cut the loops and bend the ends straight just like the branches of a birchtree. Also the angle of the branches to/on the trunk is important!
Than I dip the frame in a can with primer. let it dry
To thicken the trunk and branches I use very very fine sawDUST . I add the sawdust with a fine strainer , of course , with( colored) whiteglue in wich I add some drops of dishdetergent and a very litlle bit of water…
To make the trunk more strong just add another layer(s) of sawdust( when first is dry( I use a more deluted white glue for the next layers of sawdust)
When dry I paint the frame with cheap latex wallpaint in the right "trunk"color( or dipping them in a large can filled with the wallpaint when making 30 trees or more…)
Jos, incredible trees. Seems like quite a bit of work, yet, I see that once experienced at the process, batches could be done to speed up the process. About how much time do you figure, making a batch of 20 or so?
Those birches can also represent fall Aspens by simple repaint of the trunk.
I feel this would make quite a How To article. Great work
Thanks Bob,
Well , yes, the trees are indeed “time consuming”.
But to me as , as a " landscapemodelrailroader" it is as( even more??) important as the buildings on my future layout.
My opinion about the green stuff is that it should be as detailed as the other things on a layout like trains, cars, signs etc…specialy those who are growing in the front and of course we are limmited in immitating leaves/vegetation but I try to do my " atmost" to reach the same detailled level as the rolling stock made nowadays…
About the trees I made:
a H0pine- firtree 8 -10inches can take about max.3/4 hour including making the frame.
Modelling/twisting the frame and adding the bark will take most of the time, say 1/2 an hour. Adding the fibers and needles about 10 minutes and last but not least cleaning up the trunk ( small fibers)and a bit of weathering/drybrushing: 5-6 minutes…
H0 Atlascedar about 2 hours:
H0 solitair scotchpine took me about an hour:
yes, it will take some time to make a forrest but I don’t mind to work on it for some years and during that time it will take to make/complete the layout…( i think it will never be finished[:P])
besides that these trees have more volume/are bigger( square inches) than the ones from the industry so you don’t need the same amounts of trees…
decidious trees H0 7-8 inches an hour because I have /want to make the bark more realistic and that will take some more minutes
So true, Jos, too many times you can see well designed layout w/ exceptional highly detailed equipment and structures placed on very good scenery as to the painstaking rockwork, water features and ground covering only to be rather lacking in those most important- trees, brush and forest canopy. To use “redi-made” trees, even just a few for the important forground ones, can get quite expensive.
Thanks for posting Jos. I am impressed.
I have made some wire trees I have been reasonably happy with but I was dipping them in a sloppy plaster of paris mix to get the woody trunk look. I think using sawdust is the way to go and sawdust I got. I am looking forward to trying your method. Thanks again.
Brent[C):-)]
