I have a BLI 4-6-2 that gives me almost constant derailing issues backing over turnouts. The back set of drivers (so the first to reach the turnout) derail at least 50% of the time. This happens on various turnouts even when I am crawling over them.
Turnouts are all Peco code 83, track is Atlas code 83 flex.
These same turnouts don’t give any trouble with cars. They also don’t give any trouble with a Bachman 2-8-0 that I have, regardless of the speed I back over the turnout - including ridiculously fast.
I notice the BLI has traction tires on the set of drivers in question. I am wondering if removing them would help?
I have two other steam locomotives due back from Tony’s tomorrow (decoder install) so I plan to test with them as well.
Bill, I have a layout similar to yours. I use Atlas Code 83 flextrack and Peco Code 83 Insulfrogs. I use my finger to throw the spring loaded point rails on the turnouts. Among my steam locos, I have a BLI 4-6-2, and I have no problems backing up that loco over the turnouts.
From my experience with almost a dozen BLI steamers, when the driver wheels derail on turnouts, the rear truck on the engine is the problem. When backing up, of course, the rear truck on the engine reaches the turnout before the driver wheels. To avoid derailing, that rear truck needs to stay down on the rails to guide the approaching driver wheels. But, on a couple of my BLI steamers, tighter springs were needed to apply sufficient pressure. BLI fixed those issues for me. This could likely be the reason for your derailments when backing up the loco.
Are you using the outermost hole on the drawbar? Is the harness from tender to locomotive dragging and catching the frog point when backing? Is it all or any turnout or just one?
To be honest, I’m a max weight on drivers guy and remove the lead and trailing truck springs. After that if there is a problem with the lead and trailing trucks derailing, I add weight to the truck only. I also like to add weight to the locomotive too. But that is for pulling power.
The two trucks on a steamer, if it has two, provide no guidance to the rest of the frame and superstructure. On the prototype, of course, but not on our models. If anything, they’re an impediment to good running on our scale locomotives.
I would be inspecting the traction tire to look at its condition. If it’s worn beyond flush, or bunched, or twisted, or fractured due to aging of the material, chances are excellent that it hinders the passage of that axle around substantially curved tracks.
It could be that this one engine needs better care in how the turnout is engineered/made/laid. God knows how many times I have introduced a new steamer, and it also happens with new diesels (for me, anyway…) to my tracks and it won’t get past a certain point. All other locos I own run over that area without complaint. So, I have to experiment and finally I get it work. It’s a sunken turnout center, or its humped…just enough that a flange skips or lifts and the rest we know. It could be as simple as one axle out of gauge. Or something is preventing that one axle from slipping sufficiently sideways to negotiate the curvature (it’s called ‘lateral motion’). It might be too curved, or some object or substance wound around the axle at the bearing is preventing slide in one direction.
Drawbars with too much friction or tension on them at the pin will cause the next driver set to also be running hard against the inner flange face of the outside rail. It can cause derailments. Tethers has been mentioned. Even a uncoupling hook on a coupler could be too low and snagging, although that won’t be the case for a backing steamer, unless it’s the preceding car that is the problem.
Also, it might not be attributable to just one of these. Two or more might gang up on you and make the difference when their effect, in contribution, are summed.
Thank you - I hadn’t considered reaching out to BLI for help but it is definitely something I will explore!
Pete,
It is multiple turnouts that are causing the issue. I am using the outermost hole on the draw bar and the harness does not appear to be dragging. Everything seems fine and next thing the back most driver is slighlty off the rail, always in the same direction (ie rear of train slips to the right)
Selector,
The traction tires definitely do not appear to be new! Not sure how much wear is “acceptable” but these do look worn to me. I have never dismantled a steamer at all, let alone enough to change traction tires. Maybe this is something BLI could help with as well. I have used various straight edges to check one of the turnouts in question and I don’t find a hump or a dip. The turnout is immediately after a curve and while I was careful to make sure the track isn’t kinked I can’t help but wonder if the curve has something to do with it.
I am anxious to get the other two steamers that are out for decoder install back so I have more to test with.
Hi, does the engine derail at slow speeds? What radius curve is the track right before the switch? What switch type is it? (#4, #6, 18" snap switch, etc)
The trailing truck spring might be too strong and lift up the rear section of the train enough to the point where there is less weight on the rear driver and therefore causing it be become more sensetive to track. Try removing the trailing truck spring (all you need are some screwdrivers) and see if the engine still derails.
Make sure the wire harness isnt preventing the engine from turning properly. The wires BLI uses is rather stiff and sometimes might prevent the engine from turning. make sure no excess wires are in the way between the engine and tender.
Does your engine come with a spare traction tireless wheel? If so it should come with a tool to remove the screws off the side of the wheels which hold the rods in place. If so, we can assist you in replacing the traction tire wheel with a traction tireless wheel and see if it still derails. Personally my guess is that the traction tires dont influence whether or not the engine will derail, but who knows.
Yes, it derails at slow speeds - sometimes a crawl last night but now tonight it required higher speeds to get it to derail - faster then I would normally run in reverse.
By hand the trailing truck seems to float easily, I can’t imagine the spring is lifting the weight of the engine.
I will double check the wiring harness - no extra wires.
I bought the engine used with no spare parts in the box
I just did some more experimenting, the only time the issue shows is the diverging route. The engine gives ever the tinest hop along with an audbile click - again very slight as the back driver rides over the points. I can’t see anything that should be causing it - wondering if I should file the points a little to try to smooth it? I should mention the switch is driven by a tortoise and appears to be making solid contact with the stock rail.
Also keep in mind this happens on other switches on the layout, just focusing on this one particular spot right now.
Nor can I, but my question is whether the spring is putting enough downward pressure on the rear truck to keep it solidly on the rails.
This doesn’t sound like a turnout problem. I would not file the points. I am still fixated on the rear truck. What happens if you remove the rear truck?
Despite the lack of trouble with your other steamers, it doesn’t follow that something is slighly ‘wide’ in variance from the NMRA specs for the matter, such as flange path clearances, rail gauge for the scale, etc. Have you physically determined that you don’t have a wobbly axle that is out of gauge when at bottom dead center? Or have you checked that the gauge of the point-to-stock rail is correct all the way to the frog? Sometimes a turnout’s diverging rail, that would normally be slightly curved on the real thing and on hand-laid turnouts, is actually pretty much tangent rail. This makes a difference partway along the way to the closure rail. While your other steamers seem to be indifferent, your problem is with this one Pacific. Somehow, with a nicely laid and well-supported turnout, one axle is climbing up and out of the gauge.
Also, does the curve leading into the points run the other way, or do the points continue the same curve? IOW, are we really dealing with an S-curve here?
Charles had suggested maybe the spring was to strong, thus my last response.
I took the trailing truck off all together and still had the same issue.
I put the trailing truck back on and now the locomotive derails much more consistently. I don’t get it LOL It now derails 8 out of 10 times but I cant for the life of me see why
Wheels and points are both in gauge, just double checked.
Yes the points continue the curve.
I should point out that it is only the one driver that derails eventually dragging the next driver off with it. Trailing truck doesn’t derail 99% of the time
Okay so this is something really minor…but it COULD be a possibility.
All BLI engines have fully sprung wheels. If the springs on the wheels are sprung unevenly, it would cause the first and last wheels to derail more easily.
Imagine this: if the springs on the center driver were stiffer than the rest, and the springs on the first and last wheels were very soft, then the engine could have a see-saw effect of sorts, where either the front or rear driver has less pressure on the rails than the other.
Say if this engine was front heavy, then the rear wheel would have less pressure placed onto the rail and cause it to lift easier.
Now we know BLI uses the same springs for all their drivers…BUT (i think) the center wheel is the one driven by the motor, and therefore has a gearbox. I do believe that wheel might be more rigid than the rest due to the gears resisting up and down motion.
Or even something as simple as the traction tires being thin and as a result making the wheel be just a smidge smaller than the others…idk all this could be reasons, however unlikely.
Try placing something heavy (like a small bag of pennys, or just use your fingers) over the rear of the engine and see if it still derails. If it doesnt then it might confirm this to be the issue.
This is of course assuming that your track work isnt the issue, and everything above was attempted and failed.
Yeah, that is weird. But, it makes that spring on the rear truck suspect. I was hoping that you would report back that the derailing stopped with the rear truck removed. That 4-6-2 only has three driver wheels on each rail, and a 30" radius curve should be easily handled with such a short driver set.
Yeah, that is usually how it works. The first driver wheel derails and the other driver wheels follow suit. What seems perplexing is that the trailing truck remains on the rails as the driver wheels derail. I just don’t get that. I would expect the trailing truck to leave the rails first and then the driver wheels follow.
My apologies if this has been mentioned, but have you checked the top of the rails to make sure they are perfectly flush? I had a similar issue using Peco code 100 turnouts and Atlas code 100 flex. The ties on the Peco were slightly thicker, making the rail slightly higher than the adjoining Atlas. If so, the curve pushing the drivers against that incongruity could be allowing the driver to pick at the slightly higher lip of the rail enough to climb it.
It is a good thought, but I would be surprised if that were the problem. I mentioned earlier in this thread that I also used Atlas Code 83 flextrack with Peco Code 83 Insulfrog turnouts without the issues that the OP describes. The height difference is very slight and does not seem to interfere with performance, forward or backward. The problem here seems to be in the wheelsets, either on the trailing truck or the drivers.
A 4-6-2 wheel configuration is not nearly as fussy as, say, a 4-8-2 or a 4-10-2, so my first inclination is to eliminate the driver wheels as the problem. Some years back, I did have similar problems when backing up a BLI 2-10-2 and a 2-10-4. I sent them in to BLI, and they installed stronger springs on the trailing trucks. Problem solved. That may or may not be the problem here.
I had noticed the same thing when attaching code 83 Atlas flex track to code 83 Peco turnout. I though it was because I had to pinch the part of the joiner that attaches to the Peco turnout to get it to fit snugly. To fix it, I bent that part of the joiner down slightly to get the rails flush. I hadn’t thought of the possibility that the ties were different thicknesses.
I didn’t have derailing issues because I tested the track running at very slow speed. What happened was the loco stopped because at slow speed it couldn’t get over the raised rail. Had I first tested at normal speed, it might very well have derailed. Once I fixed that end of the turnout, I was having derailing issues with some cars when passing from the turnout onto the Atlas track and it looked like the track went down grade from the turnout. I thought it was because the turnout was right over a joint in the benchwork. I put a shim under the Atlas track and that seemed to fix the problem.
Yes, top of rails are perfectly flush. I use the atlas rail joiners which fit the Peco turnouts much looser then I would like resulting in me paying very specific attention to rail top flushness when soldering.
I will try the bag of pennys on the back of the loco. Won’t be for a day or two as the next two days are really busy (can’t wait until I retire lol)
The other thing I noticed last night is one of the pieces of connecting linkage on the drivers has a slight bend in it - not sure if it could be causing the issue, probably not but it does suggest to me that the engine has had a rougher then I would like. I am getting really close to sending the engine to BLI to see what they say.
I have two 2-8-2’s due back today (one bachman, one BLI) I am going to try them on the one turnout I have been playing with in an attempt to further eliminate a track issue.
