Hi guys
I have a problem with a BLI Paragon + QSI sound EMD SW7 HO switcher running with NEC Pro.
I bought the switcher new about 18 months ago but haven’t run it because I’ve been building my layout. So, now I have got to the stage where I can run all my locos I have acquired over the last 2 years. I ran all my other BLI and PCM locos (steamers and diesels all with sound) and they are fine but this one SW7 switcher is not good.
OK, so I know the track is fine and the connections are OK because everything else runs and I have meticulously cleaned all the track but I have severe problems with this SW7.
It starts as #3. I address it as 9390, it seems to accept it (I have the audio CV62(?) enabled) and it doen’t recognise it 9390 only #3. OK, so I stick to #3. The bell is OK, the horn is OK but the headlight only comes on at the front regardless if it’s in FWD or REV. I step it to 128, it starts to pull away but stops dead instantly after less that half an inch, no sound, nothing. I then have to select #3 again. After about 10 attempts I finally got it to pull away and it is slow (I know it’s a swicther but in comparison to my other SW7, it’s very slow.)
I tried the horn and in short mode it is fine but now and again when I press the horn in long mode, it stayed on and on and on until I selected the bell. I stopped the switcher and it wouldn’t move again.
I then put the SW7 on a standalone track 36" long and it’s just the same.
Any thoughts? (I’m awaiting a response from BLI by the way.)
Cheers
Barry [8D]
