As you know I thought the BLI’s F7 were good engines but quiet.
A Forum Member posted this:
http://tonystrains.com/tonystips/2006/060206b.htm
I ordered some packages of the Stik Tak from the Tony’s online store and waited a few days for them to arrive.
I opened the stick material and filled in the holes behind the speakers on all 4 of my units. I also taped the fans which had holes and blades in each one.
I took a section of the sticky tak from the package and used a hobby knife to slice it down 2 or three peices and simply moved the wires to the middle, inserted one blot on one side and the other with the middle blot going onto the center around the wires.
I took care to stay away from the electronics and out of the small metal holes on the speakers themselves. I used a small 2 inch peice of sprue from a kit to sorta “Tamp” the putty in.
Reassembled and tested the units on the track and thought that there was a good improvement in volume. One of the units failed to respond and I think it’s sound was turned off via DCC. We will reprogram that unit tomorrow.
Final verdict, I think the simple repairs were effective.
I marked the metal chassis of each of the B units with a F (For front) so that when I put the shells back on I wont experience funny direction problems.
The worst thing about the entire experience was the front couplers on the manned F7 Cab units. Thankfully they are easy to remove and reinstall with the one screw. My nerves sometimes are not stable enough and I have to wait until I can manipulate the small screw with some precision.
I will try to make another video of these units soon.
