BLI HO 2-10-2 Reset Button
Has anyone located the reset button in the tender of the BLI 2-10-2? I don’t have a schematic of the tender or engine.
Also, there is a trim pot and switch under neath the tender hatch. What is the switch utilized for?
Thanks
Mike.
Is this a Paragon 2 or a QSI loco?
The switch under the hatch may be for turning off the smoke. The manual reset button is on the circuit board. Remove the tender cover and look for a very small button at one end of the board. That is where it is on my Cab Forwards.
This unit is a Paragon, not 2 but just Paragon. Thanks
Mike
The original Paragon had QSI decoders and the infamous magic wand. The best way to reset these is using the 3 CVs listed in the manuals. The magic wand rarely worked. Documents can be found here.
http://www.broadway-limited.com/supportdocumentation.aspx
Some of the later QSI decoders had a jumper plug for resetting. Some had a momentary push button for resetting. Yours may have the push button. Place the loco on an un-powered track. Push and hold the button and power up the track. Wait until you get the confirmation toots or beeps or even sometimes a recorded voice saying reset. If it works this way you are lucky. Sometimes you can hold this button till your arm falls off or you die of old age. The 3 reset CVs always work.
Pete
Thanks Pete. I removed the top of the tender to discover not button. I did not look for a reset jumper.
I’ll check that out.
I do appreciate the info.
Merry Christmas and Happy New Year
