Thanks to all the guys who responded to my thread on BLI locomotive breakdowns. I agree that their service department makes a fairly good effort to keep up with things but they have produced a few foul ups too. My Reading T-1 came back from one servicing totally unable to hold the tracks. An inspection revealed that they had left the springs off of the leading pair of drivers and the pony truck. Luckily I had some driver springs that I could install and I improvised a pony truck spring as well. My C&O T-l came back from an internal mechanism repair with a new trailing truck added. Since the trailing truck is free floating with no wires or other contacts I couldn’t quite follow that move. Three separate service cycles have failed to resolve my J-1s intermittent headlight and sound problem. I’m left with the thought that they must be taking a terrible beating on the bottom line because of all these quality issues, not to mention the threat to their reputation in the industry and hobby. I’m actually having better luck buying used brass engines which are simple enough that a non-techie life me can service them in house.
No need to start a new thread. Click on the “reply” button and keep the topic contained to one thread. Multiple threads on the same subject make life confusing.
I just received my new BLI Northern 4-8-4 ATSF today. I hope I don’t have any problems with it. Last year I got a PRR M1a and it derailed once, and the whole thing was fried. They repaired it and apparently they replaced everything in the tender, due to shorting issue that fried everything. Ever since then, its been running great and very happy with it.
I haven’t tried this new one yet, will get to that later tonight. But I went to their website and registered it with an extended 2 year warranty. If you don’t, you only get a 1 year warranty.
I hear that there is only one guy doing repairs. I forget his name right now. He a really nice guy but he must be swamped. Especially with all the new releases. I guess I’ve been lucky when it comes to repairs. When my serviced engine returns it’s fixed.
There used to be two guys who did the repairs. I forget their names, but I do recall two different guys.
The use of springs on the pilot truck and the trailing truck is a favorite repair technique on BLI steamers. It seems to work, but it also seems that there should be a better way to keep those trucks on the rails.
I had a lot of problems with two Santa Fe steamers, a 2-10-2 and a 2-10-4, but the springs seeemed to fix the problem.
In my experience, if a BLI steamer works out of the box, it remains a good runner. If a BLI steamer has preformance problems out of the box, return it immediately to the vendor for a refund, not BLI for repairs. Once a lemon, always a lemon.
I do like BLI locomotives, but that is the reality of the situation.
If your J1 is like mine there are a couple of places to check. The first is to remove the front truck and tighten the screw under it. The next is to check for flash or bits of plastic left over from the molding process in the connector to the loco. I had to clean out one of mine with a pin vice and drill bit. Next is to check the other end of the tether. Inside the tender they wire tie the tether to the decoder. One of mine was so tight it cut through the wires. This is why I have extra tethers.
If you can tinker with brass you can definitely tinker with plastic.
Steam locomotives, real or model, always require more special care and maintenance.
That is reality.
I experienced only minor issues with more than a half dozen BLI steamers.
However, since I find diesels to be easier to live with, I have replaced all steam locomotives on my layout.
My new BLI Paragon E6, E7 and E8 diesels all run just fine, with no issues other than the engine idle becomes mind-numbing to listen to, and the kids and wife complain about the sound, so I turned the diesel sound level way down, and everyone is happy now.
Always interesting, in many cases the first thing I do to many steam locos is remove the factory springs on trailing trucks and pilot trucks. Not always, it depends a little on the exact design, but generally I find them not needed and a they reduce pulling power.
As for once a lemon always a lemon, I would apply that to most brands, not just BLI - maybe they learned that at BACHMANN a long time ago - that’s why they mostly just give out new locos.
I have fixed a few lemons, but I don’t have tons of faith in manufacturer service departments doing so. And from the stuff I read on here over the years, BLI tries very hard, but still fails a fair amount of the time.
I find that most of these models have built in design flaws that are easy to fix.
Example - early runs of READING T-1 from BLI/PCM seemed tail heavy and the tender drawbar would not work in the close coupled position - it rubbed the tender frame. I filed off the area of the frame that interfered with the drawbar, and added about 3 oz of weight in the big empty space in the smokebox (clearly left open for the future smoking version -
I stopped purchasing BLI after the Daylight GS4’s came out about three years ago. One of my two GS4’s became a dust collector on my desk and the other one had Soundtraxx installed to replace the BLI sound. The end result was better for the new sound decoder but the model has too many problems with voltage pick up and intermittent shorts. Several of my friends experienced the same types of problems with that particular model, but I would hope some of those models did run OK and are on layouts bringing some joy to the owners.
I’m happy to report, that the new BLI Northern 4-8-4 I just received yesterday. Is good, real good. I tested everything and she runs perfectly fine. Wheewee. Hope it stays that way.
I will repeat my earlier comment in case you missed it.
The term “lemon” applies to a lot of things, not only model railroad locomotives, but also other mechanical and electrical objects like automobiles, appliances, etc.
If something starts out as faulty, it seems to remain faulty. One element gets repaired and another one fails.
I have had this happen with automobiles, kitchen appliances, etc.
Not necessarily. My PCM (BLI) I1sa broke the axle gear. One day it was fine the next was not. Just like the P2K, Athearn, Atlas and other axle gears.
Newer runs of diesels may run good and be more reliable than model steam locomotives but they have fewer moving parts. Maintenance of the prototype steamers were massive. Heating and cooling cycles, sediments and contaminants in the water, Friction, and wear from use. The prototype were living and breathing machines built to strict tolerances. Our models are mass produced loosely fitted and sometimes not well designed.
It is not just BLI steamers that have issues. I have a Spectrum 2-8-0 that has been rebuilt twice and still has problems. My P2K 2-8-8-2 is one of the worst running locos I own. One of my P2K 0-6-0 broke some wires from the draw bar and the other the draw bar just fell apart one op session. For the price of those P2K locos I could have bought brass. Three guys in the club have the Athearn Mike and all three had to be rewired and one had the rear driver center section break apart for no apparent reason.
So here is my take on this issue. 7 BLI that 3 had issues. 3 Spectrum that 2 had major problems and one too light to pull anything. 3 P2K steamers that all had issues, and 3 Athearn with 3 problems.
Like the old bumper sticker I had with a picture of the UP Big boy that said “If you can’t run with a big boy then stay in the shop”
Although I’ve had my share of BLI steamers that needed minor repairs and/or tweaks, the “lemon factor” has not really pertained to me. Once the repairs were made by BLI, only one needed to be sent in a 2nd* time. (*The 2nd trip was for a different issue.) The other repaired models have all run just fine.
Since most of my purchases for locomotives have been online, mailing the locomotive directly into BLI for repair seemed more logical to me than just mailing it back to the vendor. I reasoned that having direct contact with BLI and explaining to them (via e-mail) the problem(s) I was experiencing with the locomotive would hopefully help them out in the long-run to understand what quality issues needed to be addressed with their own particular manufacturing outfit.
Now, whether that has really helped BLI at all?..I have no idea. All of my BlI steamers have had only minor issues. If the problem was bad enough though, I might consider sending it back to the vendor for either a replacement or a refund. Since I’m buying railroad specific models (NYC), most of the time I’d rather have the unit repaired.
My point is that if the loco is a “lemon”, it will show its true color (yellow - - - LOL) if it needs continuing repairs, for the same problem or another problem.
Not all locos with a problem right out of the box are lemons, but a problem right out of the box is a sign of potential trouble down the line.
The loco was four years old when the gear broke. Like I said one day it was running great and over night the next morning it developed the hitch in its step. It cost me $5 for the gear and about an hours time to replace it. It probably had about 50 to 75 hours of run time with and without heavy loads at that time. Except for my T1 all my BLI steamers get run at least once or twice a week that all of them has worn the plating off the wheels. My Blueline (BLI) M1b has never seen the back shop for class repairs and it must be at least 7 years old with hundreds of run time hours. Wheel cleaning and a quick lube is all that it has received since new.
