Just thought I’d provide some info on Paragon3 PRR J1 features that I learned with the help of BLI Technical Support. The items are 1) lights go out with first whistle after startup, 2) loud direction change sound, and 3) acceleration chuff volume increase.
- With some systems (e.g. NCE and MRC, but not Digitrax) when you blow the whistle for the first time after startup the lights go out – here’s how to make them stay ON.
Toggle power to tracks OFF
Power up DCC system
Press Select Loco, enter loco #, press Enter (even if loco number was already in the display)
Select F0 (see “L" appear in cab display)
Toggle power to tracks ON
Press F9 (startup sequence)
Light should have come on near the end of startup
Sound the whistle — whether standing still or moving, it should not go off
- The change of direction sound is in my opinion way to loud and you can not address its volume level independently nor is it affected by Master Volume adjustments.
You can turn the change in direction sound off by setting CV246=129 (page 208 of the Technical Reference Guide, see link below).
- To reduce the chuff sound volume increase when accelerating:
The technical reference manual can be found here: https://www.broadway-limited.com/support/manuals/techSteam1.00.pdf (More information on Chuff Control can be found on pages 14 and 15).
Try adjusting CV’s 199 and 200 until it is to your liking. Read more on those on pages 158 and 159.
Those three measures worked for me. I hope they do for you as well.
