First of all, thanks for the warm welcome and the many responses and suggestions.
One loco was purchased NEW from a reputable online vendor, the other purchased REFURBISHED directly from BLI. I’ve had both locos for about 3 years, and seldom operate them, so the headlight malfunction was just a tolerable minor nuisance. But recently, I’ve decided it was finally time to get correct operation.
I’ve been playing with DCC since 1995, when I purchased a Digitrax SUPER CHIEF set-up, and am reasonably familiar with a range of decoders, especially Tsunamis. I have used the Tsunami diesel tech manual as a reference, but BLI’s practice diverges from Tsunami in many respects, headlights among them.
Both SW 1500s have an “F” on running board of the long hood end. I hoped to cure the headlight misdirection by adjusting CVs. One of the first things I tried was setting CV 29 Bit 0 to 1, which made the loco operate cab-first In FORWARD, but the headlight on the long hood came on. And vice versa. So no cure there.
I’ve used Decoder Pro’s reset to factory defaults, then write to decoder evolution several times without correcting the problem, on both locos. Poot!
I also tried resetting CV 33 from its factory setting of 1, first to 2, then to 3, then to 0, again without any change in headlight malfunction. Boo hoo! Tsunami decoders use CV 33 and CV 34 to control F0(f) and F0(r), but BLI does not follow this practice.
I’ve also fiddled with CV 159 without beneficial outcome. After all is said and done, I’m inclined to think this is an internal hardware problem – miswiring of the two lights. But as yet, have not ventured to check this possibility out. I’ve inquired to BLI for technical advice, shortly before my forum post, and am waiting for their response.
Again, thanks
