Club has a BLI Paragon 2 N&W 2-8-8-2 which has lost its chuff. All other sounds work okay, The F8 mute works properly. The F5 and F6 (or maybe F4 and F5…can’t remember from an hour ago) work properly with the engine at standstill for blowdown and waterfill, but do nothing with engine moving to increase /decrease chuff sound.
Anyone have an idea where I can find the lost chuff?
It should have a sensor on the nether side and a small magnet or something on one of the drivers. If the magnet is still there, the sensor may be kaput, or its wiring is damaged. If those check out, it’s the decoder.
I take it that a full factory reset doesn’t get things going again?
BLI will send you replacement reed switches that are soldered onto the PC board above the main driver gearbox inside the boiler. It is a small glass tube that contains a switch and the magnet is located in a recess on the flywheel face.
They are very fragile so I suggest you buy two incase you break one (or more depending on how many BLI steam engines you have) Contact Broadway limited and for about $2 each plus shipping they will send you the “chuff sensors” or if your engine is still in warranty they may send them free.
I “woke” one up using a strong magnet but after a month or so, the chuff disappeared again. It is not too difficult to remove the boiler shell and you will see the obvious component near the flywheel. It is a somewhat common problem with BLI steam.
Well, the exploded view shows PC board part #31. The reed switch is part of this board but all you need is the reed switch to solder in place of the bad one which is not shown in detail. It looks like the smoke unit is part of this board, too.
Heres a photo from RC Grabbag that shows the sensor (and a removed one, blurry, off to the top) just ahead of the two white plugs…
All you have to do is put a dab of heat on the sensor leads and remove and replace the little glass vial that looks like a zenier diode but is a little switch. It picks up magnetic field from the flywheel below.
My experience is with the NYC Hudsons which are a smaller board but the same glass reed switch.
[edit] I don’t know if it would help but you might want to solder the reed switch onto the BOTTOM of that PC board to get it a bit closer to the magnet that lives on the flywheel. That’s what I did on one of my NYC Hudsons.]
[2nd edit!] Whoops, MY BAD! After reading the text in the above link I realize the sensor IS on the bottom! I didn’t realize the PC board was inverted for the photo![:$]
