I want to have a German steam, I have two options:
TRIX 22020 - DB CL 01 EXPRESS LOCO/TENDER 06
The locomotive has a controlled C-Sine high-efficiency propulsion in a compact design with a DCC/Selectrix decoder and a sound generator. 3 axles powered, 2 traction tires. The tender is made of metal. There is a close coupling between the locomotive and tender that can be adjusted for different curves. The locomotive is ready for installation of a smoke generator. The locomotive has LED triple headlights that change over with the direction of travel and a smoke generator contact. Both will work in conventional operation and can be controlled digitally. The locomotive whistle and steam locomotive operating sounds as well as the acceleration and braking delay can be controlled digitally with DCC, Selectrix, or Trix Systems. The sound of air compressors working, the flickering light of the firebox, the sound of brakes squealing, and a short whistle blast can be controlled with Trix Systems. Three additional sound functions (the sound of steam being let off, the sound of coal being shoveled, and the sound of the grate being shaken) can be activated with the Trix Systems Central Station to be delivered in the future. There is a close coupler with a guide mechanism and an NEM coupler pocket on the tender. Minimum radius for operation 360 mm / 14-3/16". Length over the buffers 275 mm / 10-13/16".
PRICE 495.00
PCM
Deutsche Bundesbahn BR01 4-62
Features:
- Beautifully Detailed, Accurately Modeled Locomotive and Tender Body
- Authentic Design, Paint and Color Schemes
- Authentic Sounds (Sound Equipped Units Only) and Prototypical Operation
- Many Separately Applied Details Including Brass Bell / Rails
- Detailed Backhead
- Constant
