On the BLI website, they have instructions on programming the Blue line products. Did I miss something. I was under the general impression these were DC only and now they are listing how to program them.
Are they referring to the fact you might install a decoder into the model?? If that is the case, why would’nt you use the sheet on the DCC drive decoder??
I listed their web page and printed out the FAQ.
http://precisioncraftmodels.com/BlueLine-c3479.html#programmingFAQ
BlueLine DCC PROGRAMMING Frequently Asked Questions (FAQ): Q: What is the best method to program my BlueLine locomotives in DCC? A: We recommend programming BlueLine locomotives on the main in Ops mode. If you do not know the engine ID/Address, or if the engine does not respond, set CV08 to 8 on the PROGRAM track using direct mode programming. This will reset all onboard addresses to the factory default of 3. NCE PROCAB users, please note the following tips: 1. When changing from one 4-digit address to another 4-digit address, first reprogram the engine to engine 3. Then program to the new 4-digit address. 2. When programming on the program track, the NCE system will not be able to read the CV’s from the BlueLine locomotives unless the PROCAB has the latest available firmware from NCE. The BlueLine engines can still be programmed. Simply press ‘ENTER’ when the controller gives the “CANNOT READ CV” message. DIGITRAX DT400 users, please note the following tips: 1. When changing from a 2-digit address to a 4-digit address, the system will ask if you want to enable 4-digit addressing. Respond by enter “Y”. 2. When changing from a 4-digit address to a 2-digit address, you must first enter the address, then manually reset CV29 back to its default value of 6.
