IF Chicago is so problematic, why not use another point to route those trains; either thru St. Louis, or maybe, Memphis? I think mileage might be an issue, but woukld not problems with traffic through thpse two points relieve the time in transit?
Current BNSF traffic out of the Southern California areas…Here at a possible point on their system[BNSF’s] where the traffic an either go thru Wichita and on to Chicago or turn it [EB or NB?] via the Flint Hills to the Topeka/Kansas City area.
I see a lot of COFC traffic that I suppose would origiate at s facility like North Baltimore on CSX; I suspect that because of the number of blocks of Schneider cans and Swift cans, not to mention CSX cans which coukd origin at NBOH which used to be used to be a big transfer spot for those carriers.
Of course, JBH cans are omnipresent in large numbers in either direction! Here the BNSF line splits (@Mulvane) off of what is the Southern T-con. The switch here takes the traffic in a more or less, northeasterly direction towards their big IM yard at Gardner,Ks. and then into Kansas City. and beyond.
The curious part of this is we have no point in the Wichita area, currently, where there is an IM ‘lift’; any IM freight for this area of SC Kansas comes down the Kansas Turnpike out of the Topeka/Kansas City area.
BNSF has very direct access to Clearing Yard on Chicago’s southwest side and CXS has access there from the east; so Chicago is not a huge problem for this concept. As mentioned above, I think there can be run throughs in Chicago for this business.
It won’t happen, nor should it. Transit times over the single track BN St.Louis-Avard is horrible plus any shifts would cut the boards @ Wellks. We are down to 28 pool condrs as is is now
diningcar
daveklepper
I find it difficult to believe they would use rubber-tired drayage for the Chicago connections. But I do not believe dedicated trains are employed.
Probably a run through at Clearing Yard in Chicago with just a change of crews; power remains with train.
One question answeered: Obviously no rubber-tired road transfers required. But run-through would mean dedicated trains. Unless BNSF itself consolidates traffic from the three lanes to one eastbound and splits them westbound, which may be the case, but where? Otherwise, consolidation into the single CSX haulage train and splitting westbound migiht be done in Clearing. Where else?
This is very similar to the long-standing haulage agreement BNSF has for Atlanta-area IM service. They hand the trains off to CSX at Birmingham AL and CSX gets them in to Atlanta, and vice-versa for westbound IM.
A few more such agreements with CSX (and perhaps NS?) and then BNSF would be functionally a transcontinental. Who has need of the complexities of a formal merger?
This wknd I matched up a pair of lower non-priority intermodal runs in across the BNSF newtork. The corridor of traffic from the southeast U.S. goes on the BN side west to Avard, OK., where it joins the SF for the remainder of the trip to the West Coast. .For unknown reasons the Q-MEMRIC now has been rerouted on a regular basis and given to the SF @ Kancks for the trip to the West Coast. This is good for Wellks and we will take it as the pool boards have been cut to historic lows. The other schedule being compared is the Q-ATGLAC. The Richmond train was rerouted @ Springfield to go north to Kancks (in leiu of running west to Tulsa, Enid and Avard) while the Losang stacker stayed on the Frisco/BN to Avard. Departues are @ crew change stations on dates listed and if the train was late or ahead of schedule. I have only entered the times as far west as Amaril and these two trains are still plogging west towards their destinations as I am typing this. Q-MEMRIC (rerouted between Sprimo and Avard): .Memphs: dp 0140 on 6-11 (2:20 ahead), Thayer 1040 (15 min ahead), Sprimo 1910 (1:25 late), Kancks dp 0515 on 6-12 (2:40 late), Wellks 1230 (55 min late) and Amaril 2310 (45 min late) &
The discussion over at Newswire suggests that CSX told these customers “Dray from Chicago” and instead the customers went to BNSF and persuaded them to complete the transit to Ohio unassisted. Is this really what happened here? CSX just threw away the business and BNSF salvaged it?
No, that is not what happened. There would be no reason for a truck to be drayed from Chicago to NWOH.
For those asking how the process works, the BNSF delivers the train to CSX at 71st Street via Corwith on the Blue Island sub. A CSX crew gets on and it goes east.
Westbounds are taken to 71st St on the IHB, just outside of Bedford Park. A BNSF Logistics Park crew gets on, and takes the train to Joliet over the CN ex GM&O line to Joliet.
thanks for the info you share. It seems interesting that eastbounds are taken all the way to Corwith and then down when the 71st street connection could have been made by exiting the BNSF main at McCook and running through Clearing Yard. Probably I have been away from Chicago too long and don’t know the newer operating deals and track changes that have occured.
That really wasn’t what I was thinking. Suppose there was an end user in Sandusky, or Lima, or Mansfield. And CSX was like “we don’t think the haul from Chicago to NWO is worth the bother, go get it in Chicago yourselves”.
But BNSF stepped up?
Wasn’t CSX talking about cutting back service at North Baltimore just a few years ago?
Since they appear to be run-through trains, all CSX has to do is throw a couple of switches and put a crew on board and away they go. Only one crew is needed Chicago-NWO.
If it was a matter of having to lift all of the containers and put them on a new train, that would be a different story.
