I’ve got two Bowser cabooses and both have minor wheel rubs on one end. It acts as a sort of permanent brake and occasionally derails it.
Does anyone else have this problem – and more importantly – how should I solve it?
thanks
Todd
thanks
Todd
I’ve had that problem with a couple of Bowser’s covered hoppers. A Kadee washer between the truck bolster and car body to slightly raise it, helps.
I had the same problem with both trucks on an Intermountain assembled Centralia Car Shops caboose. I was really irritated with the problem since it was almost a $50 caboose. As stated above, Kadee washer was a quick and easy fix, and haven’t had any problems.
Walthers cabooses and gondolas have this problem when negotiating 18" and 22" radii curves. For the caboose, I shave off the backside corner of the stair well that rubs against the truck. It improves it but doesn’t eliminate the problem altogether.
