Bowser turntable help
Club has an OLD bowser 18" turntable. We are having a problem with it. its not spinning.
We have applied power, and the motor we are using is functioning, and it’s getting a current to the toggle switch. The gear on the driveshaft is actually spinning on the shaft. dows anyone have any suggestions to remedy this? We tried to epoxy the worm gear onto the shaft to.
The epoxy should work. If the gear is that loose, you should be able to pull it easily enough, and the clean the motor shaft, and rough it up a bit with some sandpaper, and also clean out the hole in the gear (alcohol on a cotton swab) to get any old grease and oil off. The the epoxy should be able to make a good bond between the motor shaft and gear. If it just spins even though you already tried epoxy, it’s probably because the epoxy didn;t adhere to one of the surfaces, most likely from old grease and oil.
I have a Bowser 16 inch turntable. I built my own drive using a rubber wheel and a gear head reduction motor.
Are you using an OLD original Bowser drive? Does it engage on the wooden disc to turn the table? If so, it was easy to build a new drive using modern parts.
-Kevin
If you can remove the bridge from the pit, pull the gear and clean it as suggested.
Then, with the gear-mounting point of bridge’s shaft laying crosswise atop a mill file on the workbench (and the bridge itself hanging over the edge of the bench) press down firmly with a similar file and roll the shaft a revolution or two between the two files. This “upsetting” of the shaft will increase its diameter enough the you should be able to press the gear into place, without need to further secure it.
If nothing else works, and the parts are metal, Loctite 638 is used to seal motor cycle wheel bearings to the hub, where the hub is aluminum and the bearings have spun in the hub for reasons of improper installation.
This is not the loctite you buy that is red, green or blue in the auto store or home depot. Loctite makes a gazillion products. It will still have to be cleaned before attemting to fix it, as described in one of the previous posts.
If it is a metal shaft and a plastic gear, I have no idea. Call loctite.
I think Loctite 609 (sleeve and instert retaining compound) would also work, if all parts are metal. Again, not the Loctite you find in the auto parts store.
If you are going to try Loctite 609 or 638, be sure to clean the parts with CRC electrical contact cleaner and use Loctite’s “Primer-T” on the parts. This stuff smells awful, but it will make the Loctite retaining liquids really “Lock Tight” when the repair is done.
All these products are pretty expensive and are meant for industrial repairs. You might find it cheaper to buy a whole new drive.
-Kevin
To get a new drive for an original bowser turntable That’s gotta be expensive.
