[8D]
I have been trying to wire both tmcc-dcs using bpc’s and tpc not an easy task for me!
but I have figured it out and thought I’d share my findings with all here. I have 6 bpc’s that need power to inner and outer loops, now on the tiu set all 4 channels to fixed then connect channels 1&2 inputs together same for channels 3&4.
on output side of tiu run channel 1’s power to first bpc to t-1 then use a jumper connecting it to t-2 on the first bpc, now connect channel 2 power to t-2 on second bpc and jumper to t-2 on the second bpc and so on. I know it’s confusing but trust me it works and my signal strength is 10’s all around and I also have a tmcc and legacy engine running on outer loop at same time no signal problems or commands not working I ran this for an hour worked flawlessly. if I could figure out how to post a diagram without it being so small you need a mega magnifying glass to see it I would.
hope this helps those that want both and still be able to use tpc’s to run conventional too.
this message has been edited on 1-14-2010
