Brake Squeal for Atlas N Scale ESU Loksound S2
Does anyone know how to set the brake squeal on deceleration on the Atlas S2? The momentum is set and it works great except the brakes don’t squeal when slowing down/ stopping. Thanks for your help.
This is out of the Loksound 5 DCC Manual, Whatever Loksound you have may be different. Downloading and saving PDF documents to your computer makes them searchable.
CV Name Description Range Default
134 ABC-Mode „Sensibility” Threshold, from which asymmentry on ABC shall be recognised. 4 - 32 12
155
-162
Notch Points Notch Point 1 - Notch Point 8: The internal speed step where the diesel engine sound
notches to the next Notch (Not for all sound projects)
0 - 255
163 Sound CV9 Horn Select CV 0 - 255 01
164 Sound CV10 Bell Select CV 0 - 255 0
165 Sound CV11 Brake Squeal Select CV 0 - 255 0
166 Sound CV12 Air Dryer Select CV 0 - 255 0
