Brass hallmark sd-7 shorting out on curves
Ok I just got a steal on a hallmark brass sd-7($40.00) Looks great and after a complete tear down and cleaning of the running gear and relube it runs awesome.
Ran it all around the track with just the frame and motor and it ran flawlessly. Trouble arose however when I fitted the body back on the frame. When it comes to a curve it shorts out. here is the assembly
Now the long hood is opposite the round air tanks and I noticed that when together the long hood truck seems to catch on something. So I took it apart once more and fitted the body without the walkways and railings and this is what I found.
See where the pencil is pointing it is raised. It can rock back and forth over some pivot point I cannot find. This is what it looks like on backwards. So any conclusions on what gives???
Thanks for the help
While this is some what in the way of conjecture, it sounds like one one of both of the truck gear towers may be rubbing against the inside of the body shell when they round a curve. I’d look for bits of wire/castings,etc on the inside that may need to be smoothed down. Also rotating the trucks by hand after re-assembly might reveal something as well.
Charles
What does the assembly look like with the walkway/step assembly sitting on the bottom frame? Put the walkway part on the frame and rotate the trucks by hand as was suggested above. Check and see if the outer corners of the truck sideframes are hitting the inboard corners of the stepwells.
It does seem to catch but what is weird is when on backwards it does not catch on anything. The truck towers are the same so I do not know what is going on.
Hands down it’s the truck tower touching either the body or the cutout in the chassis. On less tight curves it probably would never touch.
I will try the walkway and rotate. but it seems it is more in the cab than in the walkway
It barely makes it into the turn before it shorts out. I could see halfway into a 20 in curve that that would be the case
The ‘not fitting’ part of the hood is probably a protusion from the fans catching on the top of the motor. When you put the hood the other way there’s nothing on the shell at that location so it sits down where it’s supposed to.
You’re right, it shoudl only short out if BOTH trucks are turned, since each truck only picks up from one rail, and each truck is suppsoed to be insualted from the middle part of the chassis - see those red washers? There should be some underneath too - if one of those has deteriorated it would allow the chassis to be ‘grounded’ to the truck with the bad insulator.
Ok well when I had it apart the red washers on top and the white plastic inserts were in good shape. like I said it runs great with the shell off so I guess I need to dig around a little more to see what is catching.
I don’t think the walkway raises it up enough to take care of the gap problem or not. i will have to dig further
