Hello–
Over on another forum where primarily diesel fans congregate, there is a recent poll discussion stating overwhelmingly that “HO brass is dead”. The usual reasons are given: today’s diesels…great value…“better than” brass. Also “collapse” of brass prices.
I must respectfully disagree for the following reasons:
First, it is true that a generation of steam fans has recently departed this hobby, if not this earth, thus leaving behind a bunch of older brass models which were built in large quantities back in the day. These models have 40, 50, or even 60 years of playing on them, have been handled and shown around, and occasionally dropped or in other accidents that have resulted in damage and parts loss, may have older decaled paint jobs that are sometimes more appropriately called “owner dipped” as opposed to “custom painted”, and maybe don’t even have can motors or good gearboxes. These models just aren’t going to bring a lot of money from anyone anymore. Some are even well used PFM Crowns that once commanded a lot of value/respect, but may have been superceded by much better running/more accurate later models. All the above can be true, depending upon one’s model preferences.
However, I just learned that not only did importers like W&R (who started circa 1986) require their builder(s) to use stainless steel valve gear and driver tires, the other builders subsequently switched as well. You can run these later models a lot before the wheels ever show any marking at all, and there’s no plating to wear off or impede electrical conductivity if chipped, etc. Division Point, later Challenger, and other importers’ brass models are well constructed and will offer superior durability to anything that one can purchase in plastic.
I just had the opportunity to really look at literally dozens of brass steamers, up close for
