I am getting back into this hoby after 8 or 9 yrs Sooo I still have my old layout and realy would like to use it but all brass track from the 1980’s OK how much of a job is it going to be to tear it out and put the new stuff in on a 6x4 layout
Am also going to expand to a12x14 foot area but plan to keep the ovel intact and add a yard with a loop at the far end hence the replacing brass just looks sort of ??? with 2 colors of rail and is also a heck of a job keeping the brass clean
tks in advance
Howard
PS This old layout is all sectional track and done from a Atlas book of track plans for Custom Line so I know the switches are differant but the track did they ever make a cusom Line track?
YES reuing this track would be a mess as was used when I got itTks
Since you only have a small layout, rip out the brass and replace it with new nickel-silver. You will be much happier with the results and have a better running system.
My layout is a combination of brass and nickel silver. Although it works OK, it is a challenge to keep clean. As I upgrade the track to nickel silver, I find a remarkable difference. Don’t be afraid to use the brass, but use nickel silver if you can.
