For several years now I have used Roberts Brick Mortar with success on several Walthers buildings. It is easy to use and makes the bricks stand out.
I tried it on a DPM Modular Building and it is just not working out. I even followed the suggestion to wipe it off with a t-shirt using diagonal swipes. Still looks like crap. Too white and the bricks do not uniformly stand out.
I then tried a wash I say Cody Grivno used on a video, namely, 1-part Model Master Acryl Light Gray, 3-drops Liquitex Flow Enhancer, and 3-parts distilled water. I tried it on a spare piece of DPM wall. This is even worse than the Roberts Brick Mortar. Way too white, does not sink in between the bricks, and cannot be wiped down to remove some of the white.
I am open to suggestions. I have seen some discussion that the DPM Modular Building walls just do not have well defined bricks and hence the reason these methods are probably not working. Have any of you found a successful way to do mortar on DPM Modular Buildings?
I am in the slow process of removing the Roberts Brick Mortar with warm water and a tooth brush. (Any suggestions on a better way to remove the Roberts Brick Mortar are welcome!) I will then repaint the bricks a brick color to cover any residue. If I cannot come up with a better approach, then I am just going to finish the building with no mortar lines.
