I am looking for some tall double track bridge piers anyone kow of any mom & pop outfit or anyone who makes some nice tall one? I have Chooch double track cut stone piers that just aren’t tall enough for the look I am trying to get. Any help is appreciated.
One solution for now might be to stand the piers you have on top of a plinth at the top of a lower pier… this can be either stone or concrete… could be stone that has had a concrete shell added to strengthen it.
Don’t forget that with very tall piers the lower stone blocks are often larger than higher ones. Also that civil engineers often raise very tall piers by levels rather than in one straight line. You can use this to figure out ways of combining smaller ready made models.
You can also make your own piers out of wood. A one-by would work. (1x4, 1x6 or whatever, and cut to the length youu need) Just cut a notch out of it. (You can use a table saw.) Paint it a concrete color and then apply a black wash. Simple, cheap, and creative modeling.
If you want stone, apply embossed stone sheeting to it.
You can also used extruded foam as well as wood, strong and easier to shape. Went to a clinic where the fellow cut pieces with a home-made hot wire cutter, then scribed in the seams between the stones with a pen tip. If you were modeling concrete, no scribing needed just paint and wash.
You can also cast your own piers and abutments using simple styrene moulds and a strong patching plaster such as Durabond.
I make my moulds from .060" sheet styrene, usually in three separate sections: two “L”-shaped sides and a separate top to suit the particular bridge. Mine aren’t especially tall, but I made most of the moulds taller than required - if I need a taller bridge, I’ll already have a suitable mould, and, by partially filling it as it sits upside down, I have a pier that can be used for a lower bridge, too.
Here’s a plain one, unassembled. I scraped some detail into the inner face of the sheets to represent the form boards which the prototype would have used. This was done before assembling the parts. The reinforcing strips along the edges help to keep the mould from bulging and also interlock with the other sections when assembled
Here’s the same mould partially assembled. I use a paper towel to wipe a light coating of vegetable oil on the inside faces of the mould before assembly - this prevents the plaster from sticking to the mould. The elastic is around what will be the top of the pier, but the bottom of the mould. The styrene blocks about half way to the other end are simply to prevent the next elastic from slipping out of position as the mould is filled. Also seen is the bottom section of the mould - the two squares of styrene cemented to the inner face will form pockets in the finished casting, which will be on the top of the installed pier, providing locators for the bridge’s steelwork:
Here’s the same mould, fully assembled and standing next to a pier cast in it. For this pier, the mould was filled only to a point slightly higher than that required, then the bottom was filed to obtain the proper height.
Excellent, excellent work there!! When you start painting the piers, do you seal them first with a basic primer like a lot of people do with plaster. Also, what color is your final coat?
I didn’t use any sealer, simply some PollyScale thinned (quite a bit, as I wanted a wash rather than paint) with water. I doubt that the colour was anything straight out of the bottle, though, as I mix almost all of my colours on an as-needed basis. I’d guess some type of grey with some buff added, or vice versa. Your question, though, reminds me that I really should weather all of the installed piers and abutments one of these days. [:I]
If one ignores the white paint covering graffiti, here is a useful example for weathering concrete. While the cement abutment is wide enough to two tracks, only a single-track girder bridge is used. While half of the bridge is mostly grey/black tones with a bit of tan, that under the bridge is mostly tan. Perhaps this is due to decades of dust falling from the ballasted-deck bridge. … Come to think about it, white cover-up paint is a detail that shouldn’t be overlooked for contemporary, accessible bridge piers.
I have to say that is pretty a work of genius the end result looks as good if not better then most of the commercial castings on the market. How did you create the top pice with the two pockets, is it several pieces glued together or did you mill out the perimeter so it would fit flush? I bet they come out of the mold needing very little work befroe you plant them as well. Also what did you use to cut the .060 styrene sheets a little think for an exacto blade?
Garry, your bridge piers turned out great and way better than I could have accomplished in wood.
The moulds are made almost entirely from .060" sheet styrene, which I buy in 4’x8’ sheets. I use a large carpenter’s square and an 8’ straightedge for doing the layout work on the sheet (on the floor of the layout room) then use the straightedge and a utility knife to cut the sheet - mostly a “score and snap” operation. For cement, I use ordinary lacquer thinner, applied with a brush to both surfaces. Use a brush sized to the job, a 1/2" is good for most, but a 1" is better for larger areas.
The hardest part was adding the detail to represent the form boards, and it really doesn’t appear to have been worth the effort. With the flat fluorescent layout room lighting, the detail is barely visible, although it may show better when I finally get around to weathering the piers. I scored the joints between “boards” with a knife, then dragged a #17 X-Acto chisel blade across some of the boards, leading with the non-tapered edge.
When filling the moulds, I poured some plaster in, then rapped the mould lightly on the top of the workbench to help any trapped air bubbles to escape, repeating these steps until the mould was filled to the proper height. I also poked a piece of piano wire into the corners of the mould where the sides meet the bottom, again to prevent air pockets.
The Durabond has a catalyst in it, so the mould will warm as the setting process occurs - I used Durabond 90, which sets in about 90 minutes, but there are other setting times available - the number following the name is the setting time in minutes. The moulds came off very easily and there were almost no voids on the surface - any present were filled with more Durabond. It’s available at most home improvement stores in, I believe, 2 and 5lb. boxes and 33lb. bags. Plaster of Paris and Hydrocal should also work, as will dental plaster, but I’ve found the Durabond to be ch
Gary, great looking piers what are the dimentions? how did you assemble the plywood with just carpenters glue?
Wayne did you find it necessary to use any sort of mold release with the stuff you used. I’ve dine some resin castings for making out of production tail light lenses and had to experiment with different mold release agents.
Hello Allegheney … The piers are about 11" tall. … I referred to MR’s book on Bridges and Trestles to determine the angels and the tapering. I used construction adhesive such as Liquid Nails. I filled the joints with spackling compound. I used a few layers of common household latex paint with sanding between each layer. The coloring is with acrylics, and I am still not completely pleased with the color. It is what it is now, though. … The entire multi-span bridge is four feet long.
I used vegetable oil as a mould release, wiping it on with a paper towel just before assembling the mould. I’m not sure where it goes during the casting process, but there seemed to be none left on the mould when it was opened and none on the castings either. I coloured the piers with a wash of water-based paint, and there was no beading-up of the paint, as you might expect if there were oil on the casting. By the way, the castings came out very cleanly, leaving nothing in the mould to be cleaned up - another wipe with oil and it was ready for another pour. [swg]
