bridge supports
Where can I find photos of various bridge supports?
Try googling Bridge Construction Pictures. You’ll find what you need there. [tup]
What do you mean? Are you speaking of the large structures that come up from the ground that hold the bridge up in the air, aka bridge piers? Or are you speaking of the small structures that the ends of the bridge sit on, aka pedestals, which accommodate any expansion between the bridge and the bridge pier? If you are looking for the piers, put “railroad bridge piers” into Google and you’ll get a bunch of hits.
If you, or any of the superdetailers out there, are interested in discussion and drawings of the pedestals, I found an interesting document starting at about page 135 at the following link:
http://books.google.com/books?id=oc8NAAAAYAAJ&pg=PA190&lpg=PA190&dq=railroad+bridge+expansion+shoes&source=bl&ots=v8q0vG9dFM&sig=f-1RuMwCGuVr7Y6gvOn06BTwArI&hl=en&ei=EqQBTNLxHcT48Ab5vN36DQ&sa=X&oi=book_result&ct=result&resnum=10&ved=0CEUQ6AEwCQ#v=onepage&q=railroad%20bridge%20expansion%20shoes&f=false
If you are looking for the supports at teh end of bridges,AKA bridge abutments, do a google search for “bridge Abutments”. YOu will find stuff under that as well, There I found this listing of some terminology you might find interesting:
http://pghbridges.com/termsBrg.htm
