Does anyone know where I can locate a 9 pin wire female jst connector by a 9 pin wire female jst connector that connects the locomotive to the tender? I contacted Broadway limited and they no longer have that part and can’t get the part. Or does anyone know where I can locate the part or how to fix it. The wires have pulled out of the plug completely. Thanks for all the help.
https://www.flickr.com/photos/190606586@N08/50436662683/in/dateposted-public/
https://www.flickr.com/photos/190606586@N08/50437364981/in/dateposted-public/
What is the nature of the plug disfunction? Is the plastic broken? Has a wire or two been pulled from the plug? Once the readers know what is damaged, we may be able to help you better/ Can you provide a photo of the damage?
Wires can often be re-inserted into such plugs just like the original assembly, if you’re careful.
Was this by any chance a 2-6-6-4?
Making your pictures visible:
Hopefully someone can help.
-Kevin
No a PCM Broadway limited Y6b connector. [:(]
Maybe the 2-8-8-2 Y6b and 2-6-6-4 Class A use a similar connector.
Every used class A I have looked at has had wire problems in the engine-tender connector.
-Kevin
