Just bought two broadway limited sd40-t they just won’t go around my radius curves they are 24" at the minimum. I have checked my track every thing fine my other SD loco make the radius fine I think I foundn out why the sold them The trucks just don’t seam to turn as much as my other SD any suggestions
I agree that from the OP’s description, it does sound like the trucks need to be looked at first. But track work is a close second. It is an “either or” situation.
One other thought might be to swap the trucks from his third good loco, if it is easy enough to remove the trucks. See if the two newly acquired locos run with known good trucks without derailing.
I agree, the problem is likely with the freedom (or lack thereof) of the trucks and trackwork.
When the OP says 24 inch radius, I assume the curve is with flextrack as opposed to sectional track. With that assumption, its possible the radius is not really 24 inch all the way around.
Another possibility is that we have seen various times where manufacturers quotes of the minimum radius capability of locos (or longer cars) isn’t necessarily so.
It is possible that the OP’s track work is the culprit. However, I had a similar problem with a BLI steamer and it turned out that the front truck was installed backwards. (I’m VERY fastidious about my track work.) Once I turned the truck around, the locomotive was happy as can be and no derailments.
With that said, if the SD40 trucks are binding somehow, it could be a wayward pickup wire that’s causing them not to rotate fully.
Came home and opened up the shell on both this is the problem with buying used you just don’t know any both loco had the pickup wire coming from the truck and it was placed so it blocked the truck from turning all the way moved the wires and all is great
I believe that the OP already said that he had found the problem…pickup wires restricting truck motion. Maybe that post was covered by one of the cookies?
