For the past week MARC has notified passengers that several PENN line trains will be one or two cars short due to not enough “electric locomotives available”. I assume that a diesel replacement loco cannot meet AMTRAK performance requirements from WASH - Baltimore with more than a maxumum amount of trailing weight (cars) . Also at present MARC does not have enough diesel locos to put two diesels on these trains since their new ones that have been delivered are still not accepted. One day MARC also stated that AMTRAK has not gotten the electric locos repaired.
Question: Does anyone know why AMTRAK repairs of these units are behind? Is AMTRAK’s Wilmington overhaul facilities overloaded with AMTRAK work? Or are there other reasons?
Now we find out MARC has 6 out of 10 motors out of service. They have not admitted to their public that this was the case only announcing that their Penn line trains would be 1 or 2 cars short. It took the Baltimore Sun newspaper to sniff out this problem. Again I ask the question. Why are 6 motors out of service?? I suspect that the new Diesel Locomotives that are not accepted will be blamed but that is bureaucratic nonsense.
Why did MARC allow so many elelctric locomotives to be bad ordered at once?
Why does MARC have to depend on Amtrak’s Wilmington facility to repair or overhaul their electric locomotives? Who repairs or overhauls MARC’s diesel locomotives?
The HHP 8’s are relatively new, so why are so many of them out of service?
This is a replay of a problem in 2005 and 2008. Then the failures were in the new batch of units and Hoover (the director) indicated heat may have been a factor. Finally, Amtrak’s HHP-8 engines were experiencing similar failures in 2005–but not today in 2009.
Also, to answer another question, Amtrak is contracted to maintain and support the engines used on the Penn Line. It makes sense since these MARC units only run on the Northeast Corridor and are very similar, if not identical, to Amtrak’s version. Furthermore, Amtrak also operates these trains under contract. It’s somewhat an Amtrak line with the Maryland DOT brand on it using Maryland money.
The current Trains Magazine Newswire mentions that 6 out of 10 electrics are out of service on the Penn Line but the article seems to confuse that problem with the separate, unrelated problem with delayed acceptance of new diesel engines (which don’t run on the Penn Line).
Actualy diesels do operate on the Penn Line! The problem with the motors out of service is that they could haul more pass cars and maintain a certain speed. Using diesels reduces the train length causing crowding and the unavailability of the new diesels prevents consists of two locomotives on the rush hour trains to get the required train length for number of passengers.
A source told me third hand that the motors not being fixed comes from MARC not contracting their motors probably because MARC is short of funds ?? Anyone know??
It must be very interesting to see the employee timetable for 40-year-old diesels that are temporarily running on the Penn Line if this is believable. I still think the two problems are confused, and I am curious to see if diesels are really running on the MARC Penn Line. They must cause havoc for through trains and others that can handle the speeds required (since Penn Line is on the Northeast Corridor where Acela and other 125+ mph trains run). I am skeptical about that but since I don’t commute on MARC Penn Line I will defer my opinion until we get the real facts.
Aero: Last time I had business in BAL (4 yrs ago) took an off peak Penn line diesel pushed train to WASH. Had 6 cars. Returned on a electric motor train of 10 cars it appeared to run much faster and accelerated faster. Time before had a 8? car push to Wash and it accelerated slow. If MARC had 2 diesels on the rush hour trains then maybe they could accelerate quicker. The diesels are not temporary except for the rush hour trains. I’ll look at schedules and try to figure required amount of motive power.
A check of the schedule requires 4 train sets for the Perryville trains - all operate with motors and have many cars.
The regular trains that terminate in BAL requires 5 train sets but appears 4 would cover rush hour. So that requires 8 motors for those trips and with 2 in for maintenance.
That leaves one round trip always needing a locomotive
Yes, NJT has the fastest commuter trains in North America. Rush hour Trenton expresses that run non-stop between Princeton Junction and Newark. (Or did?) I assume they still are allowed 100mph. Possibly the LIRR is in second place, pretty fast between Harold Tower and Jamaica on an express, and during rush hour, expresses on the Babylon line east of Jamaica. Fastest diesels may be SF Penninsular rush hour expresses. Metro North is no slouch either, but the Harlem Division expresses probably are the fastest, since both the New Haven and Hudson lines have curves with speed restrictions.
I’m assuming maximum authorized speed is what we’re talking about? I have some hazy recollection that NJT’s NEC trains are allowed 100, but MARCs are allowed 125. The LIRR used to allow electrics 80 mph and diesel hauled trains 65 mph, but practice was quite different. Don’t know what it is now. The SEPTA Marcus Hook express I used to take home from work 30 years ago used to manage the low 90s through Ridley Park with the usual four Silverliner IVs, but would just tickle 100 on the indicator with Siverliner IIs and IIIs on the rare days we had them. I remember thinking at the time that it this was likely one of the fastest commuter trains in North America at the time.
MARC’s may be allowed 125mph (AEM-7 and trail coaches, phs-pull?) but someone should check schedules, mileages, and running time. Top speed on MARC might be highest, but scheduled speed would probalby show Princeton - Newark nonstops highest.
It doesn’t appear to me that the NB Penn Line schedules are materially different than the SB. At least one train is scheduled for the 11 miles from Aberdeen to Edgewood in 7 miles. That’s 94 mph. The PJ to Newark Express trains on NJT run 34 to 36 minutes for 38 miles or 67 mph. I suspect there is padding in the NJT schedule but none in the 7 min MARC schedule.
FWIW the only AMTRAK Regional times I could find from Aberdeen - Baltimore were weekday rush hour went from 24 minutes to 28min with one 37 (actually worse than MARC) minutes. Weekends times were 22 - 24 Minutes.
Northbound 22 - 24 minutes. So with MARC stopping 2 additional stations it may be the MARC coaches are rated 125 MPH. Hard to tell. Also the note that MARC trains may leave stations north of BAL northbound up to 5 minutes early may mean the 125 rating??
