I’m having a problem I suspect is the weight in my passenger cars! When my 6 budd cars are rolling down the grade , the weight of the cars behind seem to push the cars up front (usually the closest to the loco) off the track. I did check the weight as per NMRA standards but it seems a bit excessive to me? 11 1/2" X .5 oz plus 1 oz.= 6.75 oz per car!
The down grade is less steep on this layout then on my last layout with the same cars!
How much weight do you add to your passenger cars?
The problem is likely not the weight, indeed the usual response to tracking problems is to add more. Of course if the weight is too high, or imbalanced between the two ends, or is not significantly over the trucks, that can cause issues but it is the placement of the weight, not its poundage to so speak, that is at fault.
Without seeing the track and situation myself it is hard to dignose but the following occur to me.
Coupler mountings – are they mounted to the body or are they mounted onto the trucks. Weight from behind would tend to skew the trucks if the coupler is mounted to them. It is not always practical to body mount couplers on full length passenger cars, but that is optimal if you have the broad curves that can handle them.
“Verticle easement curves.” There needs to be a transition between a grade and the pure horizontal flat. If they meet at an abrupt sharp angle that is an invitation to derailment. Let me give an example. If you took a 4’ long piece of plywood and nailed one end to the benchwork tabletop, and raised the other end to equal a 2 degree rise, there would be a smooth and even easement between flat and the rise. If you had two pieces of plywood and nailed one flat to the table and the other was at a 2 degree rise, there would be a sudden and abrupt change at the point there the two pieces intersect. Almost impossible for trains to negotiate. The more a vertical easement curve you have, the better the tracking
The curve at the bottom of the hill. Just as placing a turnout on a grade can be an invite to detailment, so can placing a curve right at the bottom of a grade be a problem as you are placing the centers of gravity at various stresses. A lack of a horizontal easement curve at that curve can also be a problem
Other track laying issues. I’d look long and hard at the track at the spot where the problems occur. Is i
Thanks Dave! I do have the weight spread out along the car! I’II move them so they are more centered over the axles!. Also the derailment point is half way down the grade but on a gradual curve!. NO track joints in the area, I will recheck the track again as well! Thanks for all the great information!
