Build the Milwaukee Road Beer Line part 2
This video is a great introduction to soldering, and suitcase connecters!
Since the Beer Line is modular, I was wondering how the
individual sections are wired at each end to accomodate easy connection and disconnection.
I wish you would use something other than flash player it - would be great to watch this on my iPad.
Good video. One question… why did you attach the 2nd wire to the inside rail??? Would that not hamper the train wheels?
Great video. Very Informative. What is done with the black ground feeder wire from the rails?? Is it attached at the opposite end of the suitcase connectors??
Terry’s explanation of how to use suitcase connectors was great - really cleared up things for me. Thanks Terry.
Terry just a couple of thoughts. I first drill the hole through track bed between the ties that hold the track I will be soldering to. I then bend the tinned wire into an “L”. After feeding the wire through the hole I can solder to the track. Secondly, just to completely eliminate any possibility of a problem with the wheel flanges, I never solder to the inside of the rails. I like to be as safe as possible, it stinks to try to cleanup the track after some overzealous soldering. Ask me how I know.
Thanks for the great suggestions, examples, and ideas. I am beginning to look forward to and use the plus segment more than the actual magazine. Keep up the good work and great video(JM).
I have no problem viewing these videos on my iPad. I touch the arrow and it plays.
