Building a backdrop - Phase II Comments/advice?
Welcome to Phase II of my backdrop construction.
As you’ll see in the 1st pic, covered the seams in the poster paper with 1 1/2" wide masking tape.
http://i61.photobucket.com/albums/h80/jeffrey-wimberly/bdb1.jpg
I continued this all the way down the wall.
http://i61.photobucket.com/albums/h80/jeffrey-wimberly/bdb2.jpg
.Deleted due to copyright changes. 01/17/07
Now for the paint for the backdrop. I use a flat latex paint called ‘Nimble Blue’ for this. It will dry to a very nice looking sky blue.
http://i61.photobucket.com/albums/h80/jeffrey-wimberly/bdb8.jpg
The first coat is already on the first sheet of poster board. I’ll do the entire length, then put a second coat on. This will fill in any areas the first coat missed and will insure uniformity.
http://i61.photobucket.com/albums/h80/jeffrey-wimberly/bdb9.jpg
The entire length is now done in two coats. I left one little area unpainted so you can see the difference between what color the poster board was and what color it is now. Quite a difference, isn’t it?
http://i61.photobucket.com/albums/h80/jeffrey-wimberly/bdb10.jpg
Very nice, Jeffrey, and a big improvement on the sky blue. Good job.
Very nicely done, Jeff. Wish I had your talent.
When you’re in the diner have a drink on my tab.
Flip
Thats amazing Jeff, Im going to have totry that method. Cant afford those expensive ones at the hobby shops. Looking good. Dave
Where did you buy the Nimble Blue color at? What brand of paint? Looks good!
It’s ColorPlace paint, available at Wal-Mart. I get it mixed as a medium base flat latex wall paint. The color number is 91424.
Anybody else?
Jeffrey,
very awsome way of doing the backdrop. If I didnt have walls Icould paint I would do it this way I applaud you. One questions tho do you find the pictures of the cities online and where at or do you just go take photos then print them on your printer?
Hmmm, I posted this a while ago but it seems to have vanished…
I don’t see a step where the masking tape is removed after the white glue on the scenic sheets has dried.
Nice work!!!
underworld[:D][:D][:D][:D][:D]
It doesn’t get removed. It’s on the backside of the scene, therefore it won’t be seen by anybody once it’s mounted. I used duct tape on the old one. No one besides me ever knew it was there.
I looked at the Backdrop Warehouse website briefly and didn’t see any copyright information on their samples, so you’re probably good there… You may want to check, though.
Otherwise, looks good! I’m amazed that the poster board keeps its shape even after you paint it with latex paint.
This is a tried and true method I’ve been using for many years. As long as the poster board is secured at top and bottom, it will maintain it’s shape with the exception of a little bowing while the paint is wet. This soon disappears.
I use regular plain everyday copy paper available from Wal-Mart.
[quote user=“jeffrey-wimberly”]
Dave: This is their copyright information. What I’m doing is safe. The files are not copyrighted, so I can do what I want with them.
There is an easy way to view each scene much larger than the expanded view, almost actual size.
  • Bring up the expanded view of the selected scene. (sample button)
  • You cannot save the view with the stock number, you must use the expanded view.
  • At the top left of your browser there is the word File, click here
  • On the drop down menu there is Save As, click here
  • You are prompted for a place on your hard drive to save the file. Find or create a folder to put the image file into.
  • Use the default file name (like MT-WSKL-93M.jpg) and be sure the . jpg is at the end. AOL users may loose part of the name. This is ok as long as the name is different for each file saved and . jpg is on the end.
  • These files are not copyrighted so save away.
  • Click on Save
  • Minimize your browser
  • Find the file just saved and double click on it.
  • If it doesn’t open you may have to find imaging </
Opps, they must have seen your thread and not liked it. It appears that the copyright has changed. Look at the date. I looked at the expanded view and agree that the file size is not large enough to give me a suitable print. Walthers cartoons would look better than a jpg at 150kb. I assume that one of their prints is in the multi mb. It depends on what you are willing to accept but you risk trouble making a backdrop from their images. I don’t know what the copyright was before the date indicated.
Ah ha, I see, they went and changed it.
