Here is a tutorial on assembling Ho-Scale Jordan vehicles. The assembly sequence, painting, and tips presented in this post are based from the experience I have gained over the years with this product. If you have never build one of these models, I invite you to come along with me to see how I build these cars from start to finish. Those of you who have build Jordan Vehicles in the past, perhaps I may be able to pass on some tips you may find useful:
#1 shows the Model that was used for this presentation. It is a 1928 Model “A” Ford Pick-up. However, these methods and tips can be applied to any of the Jordan vehicle line. Also shown are the minimum tools needed to assemble these models. You will also note I included Amber colored lenses (#202) and a piece of strip wood. These two items will be used to simulate headlights and wooden truck bed.
#2 shows the contents included in the kit.
#3 before assembly, it is necessary to remove any flash from all parts. A sharp razor and needle files does this job nicely. Remove the remaining details from their sprue and clean up with you razor and files.
#4 the first step of assembly is the hood. (Tip) liquid cement is used for this step. Align the left and right hood sides to the core-block. (Tip) use a flat surface, such as a sheet of glass to align the bottom of the sides with the core. Once set, glue and install the hood top (evenly centered) on core-block. Set the completed assembly aside for now.
#5 the next step is the under carriage. This should be done prior to any painting (I’ll cover that later) to insure a good
Bob, thank you very much for the effort to put this together. I am on a business trip to Florida and it looks like there is a good hobby shop here in Sarasota that I hope has a Jordan vehicle to get started on.
A question. What ratio of ink to alcohol do you use in your ink wash?
Simon:
The ratio of ink wash is the same that I used to weather the stripwood for the bed liner. (2 teablespoons of ink to 1 pint of alcohol) BTW, this mix can be used throughout the layout including structures made of wood or plastic.
Bob, very nice work but (you knew there was going to be a “but”, now didn’t you?) how did you achieve that effect of rotted concrete on the bridge in the last picture?
Thanks Bob, of course the information was right in front of my eyes! I guess I should focus on the forum, rather trying to watch the AI results show and the Cardinals game on ESPN at the same time.[:I]
To achieve the “aged” concrete effect (btm the bridge started as a Rix plastic model) I mix floquil concrete with Durham’s water putty. This adds texture to the paint. The trick is to stipple the paint onto the bridge in lieu of brushing it on. If you let the putty harden somewhat you can achieve a more textured look. Just remember to work in small patches or scrap material until you achieve the results your after. And always follow up with the alcohol stain mix as described in this post.
Great clinic. I got one built this year in AZ. Not as good as yours, but the learning curve is started. Eventually I want more. I am putting sound in an old brass articuated at the moment, and talk about a learning curve. The power wires greatly affect the articulation movement.
Bob, Great work on the P.U. truck. Thanks for the very helpful tutorial. I will now take up the challenge on several Jordan vehicles I recently purchased. They do make a scene really pop when done as you demonstrated.[:D]
ps. really enjoy your posts. especially the photos. Keep up the great work.[:)][:)]
Thanks Bob. I had often seen Jordan vehicles at my LHS but never bought one. I think you’ve done a good thing for Jordan. Their sales may increase due to your excellent results. I am gonna give it a try.
Bob, thank you for taking the time to make this up for us. If you don’t mind a question, what cements specifically do you favor for projects like this? I’m a bit new to the world of modeling so any advice is appreciated.
Jarrell
One of the reasons that I keep feeling the tug to backdate to the 1920s is because of the really cool old cars that I could model. a '57 Chevy does nothing for me, but I’ll run across a busy street to get a better look at a Model A coupe! My dream car is a '32 Packard.
Great job building and detailing that truck. But one question - didn’t Henry Ford, back in the day, say “We have any color you want as long as it’s black”?
