Ok guys, this is in no way supposed to be a clinic, or a tutorial of any sort, it is merely the steps I am taking and the methods I am using to create my trestle. Hopefully it may help someone out there, at the very least some may find it interesting.
I decided to do this as a motivational thing for myself to keep my momentum going throughout the building process and also pass on some of the things I discover along the way. As some of you know I have finally started building the Kinsol Trestle, it scales down to 7’ long and 2’ high, with a total of 41 bents.
Part One - The Jigs
With this much repetition jigs are a must so the first stage was to create these. I made a double sided jig, one side for the bents,
and on the reverse side I mapped out the supports for the actual river span section.
as I was also going to be cutting all the wood to size myself I added a cutting jig on the bottom of the ‘B side’ this is simply made from some 1/8 x 1/8 balsa and ensures that all the bracing strips are exactly 1/8 wide.
Step Two - Starting Construction
Roughly working out how much wood I would use I placed the order @ the LHS ($85) now the fun could begin,
the tools I am using are shown below this is all I have needed so far. I found that replacing the nozzle on the wood glue with that from a white glue bottle gave enough control to just place the glue direct from the bottle without the need to squeeze out a puddle and apply with a toothpic.
I drew a highly detailed plan to enable me to work out ho
