I purchased Tru-scale Structures Union Ice Company Kit. I love the look of the finished structure but I am having some difficulty with the old kit. The cooling tower is constructed from pieces of card stock which the instructions say to tape together. The tape in the kit is old and in sad shape. I could use some other tape but I am wondering if it would not be better to just glue the four sides of the baffles together? I would probably need to use some removable tape, like painters tape to hold the baffles in shape while the glue dries. I think this was a popular kit back in the day(probably way back) so I thought there would be some people around who have had experience with this kit. If anyone can offer any advice (no, I will not toss it) I would be most grateful.
My only advice is painters tape can stick very aggressively. A trick I saw on Off the Tracks is to stick it to something, like a counter and remove it, re-stick it and remove multiple times until it’s less sticky.
I would not use any kind of tape at all…instead, glue it together without any need for the tape. Glue a long side and short side together, do the same for the other side, then glue together to form one piece. You can do more than one at a time…once cured…put together. The adhesive I highly recommend for doing that is Northeastern Flamingo Glue…drys in 5 minutes, goes on pink, but drys clear and is very strong. I use it all the time for any scratch building requiring the use of wood and or cardstock…I use Illustration board 1/16’’ thick…looks like poster board/Mat board. The link for the glue:
Love this building design. However,these kits are old technology. Cardstock parts are famous for warping over time. I would suggest that you cut out the cardstock parts in styrene and build a styrene version. The model will still need internal bracing, but (IMHO), the outcome will be better.
If you decide to use the original cardstock parts for the ventilator, I suspect they will warp pretty quickly (depending on the climate) as there aren’t many places to brace them. In general, I seal both side of the cardstock with paint before assembly and then brace the heck out of the structure to minimize the warping issue. I wouldn’t use tape to permanently hold the ventilator together.
I chose to scratch build an icing dock ventuilator building from styrene:
