I directly wired the lamps in my 042 switches. The power was turned up too much and one lamp melted. Now, I cannot get the switch to turn on with a new bulb. Any idea on what I need to address?
Just guessing, but you may have fried the wiring inside the switch itself. If I remember those switches correctly you’ll have to remove the steel plate on the bottom of the switch to inspect it and maybe rewire it.
And [#welcome] aboard!
There is literally just one wire. If you wired it for constant voltage, you can find where the break in the wire is.
