Burnishing rail??
I just spent the last 90 minutes looking over a host of posts here and elsewhere, on the general subject of rail cleaning, specifically whether or not to use abrasive “bright boy” style products. Surprisingly (to me at least) some folks still apparently swear by them. I keep wondering why anyone would, as I have, gone to the trouble of laying track only to grind it down. Even though a word often used to describe the damage abrasive cleaners create along rail heads is “microscopic,” the problems of sharp abrasive trails of scratches seem ultimately self defeating.
There were a few - just a very few - mentions of rail burnishing, but I haven’t seen anyone discuss it in greater length than passing mention.
Does anyone - has anyone regularly burnished their rail?
In my wood shop I often use steel scrapers finishing wood surfaces, so I acquired the tools to maintain those scrapers. One such tool is a hard steel burnisher, which gets used often.
I’m wondering if anyone has comments about the efficacy of actually burnishing their rail? Seems to me there’d be some merit to at least occasionally doing so, but if anyone is willing to share experience that’s be awesome.
The late Jeffrey Wimberly (Running Bear) was a big fan of the “Gleam” method.
Here’s a link…
https://cs.trains.com/mrr/f/88/p/221146/2443407.aspx#2443407
Cheers, the Bear.[:)]
Plus one, emphatically. I followed this method when Jeff posted it. I swear by it.I DO NOT clean track anymore, unless some scenery material slops on it. Then, a wipe with some alcohol on a scrap of cotton, rub a steel washer over it then a chunk of cork roadbed and I’m good to go.
I haven’t run ANY trains for at least 2 months and I can say with certainty if I turn on my Digitrax system I will be running trains without stops or stutters on my sound engines. Well, unless something has fallen across the track. Like a tree or something.
My layout resides in a finished 30’ x 42’ basement, and takes up the entire area. It was at least 95% fininshed when I heard of this method. Yes, absoulutley it was a PITA to follow the procedure.
But I’m glad I did.
YMMV
Terry
I’m a big fan of the gleaming method, but have come to the conclusion that the heavier grit paper…
"1) 400 wet/dry paper to remove the extrusion milling left on the railheads. The block must span both rails. And 2] Now use 600 or finer, repeat process."
…is not necessary. In fact it just makes the burnishing step much longer and harder.
My Gleaming Kit now has sheets of abrasive grit values of 1000, 2000, 4000, 6000 and 12,000 (and you can skip steps). Once you get to the 12,000 grit, burnishing with the washer is an option since the mirror shine is already there.
And it sure saves a lot of the old “elbow grease!” I’m not sure I could even find my old bright-boy now.
Jim
The progressive use of higher grits is subtractive machining. Burnishing is a different process: it forces down the peaks of the ‘scratches’ left by the abrasive, and can work-harden the surface.
Part of the reason to use the full range of grits is to remove any existing pitting from ‘micro-arcing’ and to keep the scratch peaks from acting as formation sites for new ones. The Bright Boy surface finish fails miserably at providing other than intermittent line contacts between wheeltread and railhead.
I personally like the use of lapping film applied to a properly-shaped hard (e.g. glass) lap that shapes the railheads to a proper contour as well as smooths their surface finish. But the ‘final step’ even with very fine grit ought to be burnishing.
Hello from Semafores. My name is Richard Breton. I originally posted the apparently non-valid link back inn2006-2007.
I discovered the proper profile and finish for railheads of Any Scale; I mostly associate with HO.
I happened on the technique by analyzing the profile of model rails to prototype rails. The contour is a slight dome. Model track mostly have a Flat top profile. [ I
make a dome profile ( along the railhead first, by sanding, with 400 then 800 grits on the inner and outer edges a bit. Wipe away the spoils each time.
The train’s weight roll the shiny finish, whereas I introduce force applied through a Stainless Steel tool, in my case a 1/2” cut washer. Rubbing along the railhead following the dome shape will make the shine.
The science is that with less gaps, the electric arc is practically eliminated. The arcing produces nickel oxide, the funky black residue.
The shine is a hard shell that resists the pitting of the metal also.
Adhesion improves on the locos and drag reduces on the cars.
The dome profile also lets any gunk squeeze to the sides and the engine keeps running smoothly. And helps keep wheels cleaner.
Of course is takes time, I do 3’ of HO in about-0 minutes.But you only need to do this process Once. Occasionally it will need a dry wipe with cotton T rag. When you feel like it.
Single engine operation is great.
I’m a member of the Souh Florida Railway Museum in Deerfield Beach, Florida.
SFRM.org
Gleamed my track when I put it down in 2006, did a light once over in 2018. Wipe it down now and then, especially sidings, Happy camper
