Buzzing DCC BB...
Two locos with the same issue…
I recently installed a Digitrax DH142 on a newer BB GP38-2. She runs ok once she gets moving (and ran fine prior to conversion to DCC), but before she gets underway she buzzes until reaching speed step 7, and then takes off. I have done the basic Athearn Tune-up, and hardwired the motor, “erased” the commutator, cleaned the flash, and lubricated the gears.
I know the DH142 isn’t a “silent running” decoder ( i have a DH163 i could use, but i don’t need all of the FX’s) so adjusting CVs isn’t an option…the second loco is a newer SD-9 with a DZ123. This decoder is Supersonic (silent running) equipped, but I’m not sure how to go about tweaking the CV’s (kick start, etc) to achieve quiet(er) running. I would think that I need to resolve the issue of getting them underway before I can begin to tweak the CVs (on the SD-9 anyway).
So… What has proved successful for you in loosening up the Athearn drive to facilitate smooth operation and/or overcome the buzzing? I’ve read of people shortening the brush springs, "Goo"ing the magnets to reduce vibration, polishing the commutator (which frightens me), using Pearl Drops to “wear in” the gears, rubber bands or aquarium tubing to take the slop out of the universals, “Conducta lubing” parts…I am plan to upgrade the wheels to NWSL or JB Nickel-Silver and may see if I can locate some Conducta Lube at the Syracuse show. Re-motoring is outside of my meager budget, so it is off the table right now. What has worked for you?
You are on the right track. I will sum up here (and these work like a charm)
  1. The running gear should be taken apart and clean off all of the Athearn grease. Then it should be re-assembled and run with a bit of Pearl-drops toothpaste as the paste has fine granuals in it that will polish the gears and allow them to mesh better. After about 30 minutes in each direction, dissasemble again and clean (I find a sealable container with soap and water works best…just shake to clean). Reassemble with a good quality plastic-compatible lubricant.
  2. In terms of the motor, there are 2 things that can be done…the first is to remove the brush springs and cut them in half. The second is to clean the commutator, add a mineral oil to it and then completely remove said mineral oil. It will penitrate the commutator and the result is a smoother running motor.
There are other things to do with Athearns, such as fixing their electrial issues…but that is another story.
David B
David- Thanks for the suggestions. These will obviously help with getting the locos underway, but will they also reduce the buzzing? Can you recommend any steps I might take with the DZ123 Supersonic equipped decoder? I gather from the Digitrax site that the Supersonic is enabled from the factory, so it puzzles me why the motor buzzes. Is there a way to adjust the pulse rate or otherwise stiffle the bees nest?
Can anyone explain how to go about adjusting the kick start and other pertinent CVs that will allow for smooth start-up? The Digitrax instructions are less than helpful[tdn]
Thanks
Nope, the buzzing is a result of the early decoder. The 123 should buzz at all…or put another way, the buzzing should be reduced by the modifications to the motor.
The other option would be to repower…
In terms of programming your decoder, it is very easy.
  1. You need to set your CV2 (START VOLTAGE). Put the loco on the track, set the throttle to speed step 1. Enter OPS mode programming and start setting CV2 until the unit starts to creep. A typical setting for an Athearn is very high (40-60). This is normal.
  2. Set your top end speed (CV5) and then set CV6 to be half of Cv5.
You really dont need kickstart.
David B
That’s it?
After attempting to read the Digitrax instructions I was thinking I would need to call NASA for help…
I am no rocket scientist (probably why i can’t decipher the instructions)[D)]
Thanks for the info.
Yup, that is it. Remember that the Athearn setting for CV2 is quite high. A Kato, by comparrison, would have a value of 0.
David B
IMHO Digitrax instructions are either non-existant or fairly poorly written and confusing. I’d suggest trying TCS decoders in the future, they can do everything a Digitrax decoder does, and their worksheet that comes with the decoders works you through the CVs step by step, explaining what to enter to get a particular result.
BTW I’m not sure re the Digitrax supersonic decoder and the buzzing issue, but I beleive some decoders have features like that that only kick in if CV 2,5 or 6 is a value other than zero (the default value)…so sometimes just changing one of those CV’s will ‘turn on’ the feature.
They can’t do Transponding.
