Cajon Pass & Cookie Cutter Method
Hello Everyone,
I’m new to the hobby and I’m interested in finding prototype information on the Cajon Pass and with some photo’s. Is there a specific place to go on the web?
Also, I’m going to be using the cookie cutter method for the bench work. Is this a good idea or are there better ways.
Thanks to all for for help with this.
Louie
Hi Louie;
You need “Modeling Cajon” by Peter Youngblood, unfortunately out of print.
And should probably get “Santa Fe in the Mountains: Three Passes of the West: Raton, Cajon, and Tehachapi (Golden Years of Railroading)” by George H. Drury
Personally, I am believer in foam; 4" of extruded foam on 3/16" plywood, Woodland Scenics foam roadbed, and risers as required. Alleene’s Tacky Glue (http://www.duncancrafts.com/products/product.asp?ID=51&SID=12) is used to hold it together - I get it at Wal-Mart.
Nigel
Nigel - Some questions:
What do you use to support the plywood? If well-supported (say every 16"), do you think you could use even thinner plywood?
I like Alleene’s Tacky Glue, too, for the roadbed-to-foam part, but do you use it to glue the foam to the plywood as well? (I was a little leery of using it for that, so I used Liquid Nails.
Did you get 4" foam by layers, or where did you find 4" thick foam? If layers, did you use Alleene’s there as well?
Thanks,
billk
PS I see you registered at The Gauge a while back!
Try the site for Ted York’s Cajon Pass HO layout. He has a number of prototype photos also.
http://mywebpages.comcast.net/cajonpass/index.htm
Rob Spangler
WP 8th Sub
Layton, UT
