BNSF derailed a coal train in Hudson ( ~ 30 miles NE of Denver ) going into Denver. The train derailed in town but did not come apart until an unknown distance out in rural area. Unconfirmed reports say due to much track damage Cal Z will detour Omaha - Denver. No route details yet.
This line is joint UP, BNSF< Amtrak line.
http://www.9news.com/story/news/2015/03/22/train-derails-in-weld-county/25181437/
http://www.denverpost.com/news/ci_27763975/coal-train-derails-near-hudson-no-injuries
Unconfirmed report Cal Z both 5 & 6 will travel UP Omaha - Denver.
I guess they will have to go thru Cheyenne, since UP abandoned Ft. Morgan-LaSalle.
No more Julesburg-Denver cutoff? That one is hard to figure. About how long ago did that happen, Mike?
I have a memory of reading something about the abandonment of a section, but I do not recall how long ago it was. The Bing map of the line shows that the track is still there, and SPV’s map (1995) shows it.
Please note: I corrected my post (2 above) to read Julesburg-Denver.
Fred, may I make another correction? The line ran from Julesburg to La Salle, where it joined the Denver-Cheyenne line.
Right you are, Johnny – thanks.
Julesburg-Sterling segment is still there. At Sterling UP and BNSF merge, and UP would have to use BNSF’s route to Denver, since UP abandoned most of that line west of the Ft. Morgan area. There is also a remnant that runs for about 10 miles east of LaSalle. The abandoments were in the 1990s.
www.trainorders.com/discussion/read.php?11,3054599
Yes! I remember now. The CZ would run on its usual route west of Brush, on the BNSF branch to Sterling, and then on the UP to Julesburg and east–unless it used the UP all the way from Denver through Cheyenne.
Mike: So UP must use BNSF trackage if it wants to take the short way to Denver? Sure seems odd – but then, I’ve been gone from there a long time. I’ll have to look at a map. Maybe traffic off the Omaha line finds its way to the upgraded KP (and thence to Denver) further east?
From Altamont Press’s June 26, 2005 Rocky Mountain Region Timetable, I see that the UP’s line southwest from Julesburg is dark territory to Sterling (57.5 miles) and then has ABS to Union, where it connects with the BNSF (BNSF has trackage rights Sterling-Union–controlled by BNSF DS). BNSF has CTC Union-Brush-Denver.
From Sharon Springs, Kansas, to Pullman Jct. (in Denver), the UP is primarily dark, with ABS in various towns along the way.
Quite interesting, isn’t it?
UP’s system map just shows the Julesberg to Denver route described, although one of the previous links seems to indicate that they don’t use it much. I guess that Cheyenne is the normal Denver connection with the Omaha line.
