I just bought a large accumulation of HO model railroad stuff including a ton of craftsman and museum quality kits. Can anyone tell me about the California Model Company? I found some references in Google but they seemed to be about airplane models. I have four building kits that I’m trying to research. They are a combination of etched metal and wood. Any help would be appreciated. Thanks.
California Models was Suydam.
I can’t tell you much about them, except that I have a few kits in boxes that I recently dragged out of my storage shed (they are my brother’s though he never completed them). I do have an address on one of the boxes, but I don’t know if they still exist. Here it is:
California Model Co.
1420 South Ritchey, Unit E
Santa Ana, CA 92705
I didn’t find any instruction sheets in the boxes (yet), but I haven’t looked through them completely, either. I hope this helps a little bit, at least.
I’ve got a few of their kits. They usually turn out nice.
They are now:
Alpine Division Scale Models
P.O. Box 6
Artesia, CA 90702
jdavid93225
I have the instruction sheets for the grain elevator and the furniture factory. I can scan them and e-mail them if that’s what you are missing.
Tom,
The boxes I have actually belong to my brother, and they are a roundhouse and a roundhouse extension, as I recall. At this point, I don’t know what he would like to do with the models, so I’ll have to check into that. Thanks for the offer, though.
Sorry I didn’t reply sooner but I’ve been sorting through 22 cartons of HO model railroad stuff from an estate. What an education! Thanks for the info on Alpine Division Scale Models, I’ll chase that.
I had their catalog (Suydam) back when I was like 10 years old. I spent weeks looking and drooling over those buildings, in my mind I had the ultimate layout with all their buildings. I never owned one. Are they as sharp looking in the catalog as they are once built? Were they tough kits to put together?
I think mine look good. But I changed the colors a bit. Painting is time consuming, but hardest part is keeping things straight when you are glueing. It’s a little harder than a plastic kit, but not significantly harder. I just started an all-wood craftsman kit. I don’t know how it will compare.
Currently they have a website:
http://www.alpinemodels.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=ADSM&Category_Code=100
They had both cardstock and metal building kits back in the days of the Suydam name and many of them are still listed in the website. The metal ones will require some soldering to assemble and I have put a few of them together MANY years ago. The corrugated metal looks like corrugated metal because it is.
They’re easier than an all-wood craftsman kit.
I may ruffle some feathers here but this stuff was state of the art 1960. I built a couple of the metal kits years ago. I soldered them together. I looked at them in the 90s’ when I got back into the hobby and they are grossly out of scale with pretty crude details. The corrugated metal scale out to have 6" wide corrugations. Compare to the Campbell’s corruagated metal and you will see the difference. I would be wary of older kits with lots of cardboard. I usually replace the cardboard with styrene because unless the cardboard is carefully braced, it will warp on you. Especially if you paint it or say glue shingles on it. Nothing more frustrating than to shingle a roof with the campbell’s shingles only to have it warp.
How difficult to assemble? Pretty hard to get the solder joints to line up and look right. IMHO now there are so many kits out there with far superior details that will take you same amount of time or less to assemble why bother with these?
As many of you know, just because it is hard to put together or takes great skills to pull it off doesn’t mean that you will end up with a highly detailed, great looking model. Some guys are throwing around the term “craftsman kit” a lot these days. Does this mean highly detailed and a lot of work or simply high level modeling skills are needed? My definition is higher level of skill to assemble the kit to reach a higher level of detail in the assembled model. There are a lot of older kits where a high level of skill is needed to assemble them but they don’t reach a high level of detail…Are these craftsman kits??
I kinda sorta agree with you, but I kinda sorta don’t. I think it depends on your era. For pre 1920 and especially for old west, I have found 3 options. Suydam, Muir Models and Campbell. There are some other older things out there, but I have only found them pre-assembled and they were not as good as the three mentioned. I’m not claiming a lot of experience here. I have built 2 Sudyam models and I picked what looked like the hardest of the Muir models, a silver mine as my first wood model. It is not an easy put together and I don’t know what it will look like when I’m done.
Yes, the cardbooard warps when you paint it. The shrinking pint does that. But if you weight it, it straightens pretty well. BTW: wood does that too.
However, the worst warpage I had was in a styrene kit. It came that way.
I have a Suydam (California Models) catalog. Currently I am building the “heavy industry” kit; American Chemical and Potash,with annex.This building is BIG!!!. All of the kits,including mine require use of a solder and a soldering iron.If you are uncertain about using a soldering iron,I am “experimenting” with Gorilla Glue.This stuff is FANTASTIC!!! Although I must say,use this glue VERY sparingly. Take a tooth pick,dip it in the glue,and cautiously sread it along one piece of the metal to be fastened together.With the other piece to be glued,I use a paint brush,dipped in water and form a line of water beads along the edge.Then I fasten the 2 pieces together,and clamp it with some “Tool shop” clamps.(These clamps come in a tube,are various colors and are in different sizes and work very well.) This glue will form a tight bond and there will be a little bit of foam along the edges.I just trim the excess,and once I have the whole structure complete,I paint it. Do not put the windows in until you have painted the structure.I went to a hardware store and found an “industrial” blue color,which I used to paint the building. I have used a soldering iron on the tank part of the building,though I find this very difficult to do,especially when the darn iron likes to "cool off ". So far the building is coming along great.I do recommend that you DO read the building instructions carefully,before assembly,that way you know what you are going to be putting together.Have fun with your kits!! If you or anyone would like something from the Suydam catalog I have,please feel free to email me.
Chip,
There are other kits that fit your era, Check out the narrow gauge stuff, The Narrow gauge & Shortline Gazzette or google Narrow gauge. I’ll see if I can get specific names for you. Have you checked the manufacturers I listed in the above post??
QUOTE: Originally posted by jdavid93225
Tom,
Had a Suydam roundhouse way back when,Its the metal one right? S’where I learned (the hard way) how to solder…[:D]
The trick I found for this is to use medium to large hemostats to align the ends of the metal strips and hold them while you solder the middle. Then remove them and solder the ends
“Craftsman Kit” traditionally has meant a craftsman’s level of skill was required to assemble the kit, in other words, not recommended for beginners. I’ve never done any of the cardstock ones, just the metal and I agree the small buildings look bad. But large industries like the American Chemical and Potash one (with annex) is an impressive sight because of it’s size, which also makes the “6 inch wide corrugations” not real noticable.
Chip,
Guy,
I have come across some of the ones you’ve mentioned, but not all. The Builder’s in Scale stuff is way beyond my price range. I have the Mangnussen Victorian Arms Hotel, but I fear it will not fit into my layout. The biggest twon o the layout is about 3000 population. And that hotel is huge. I fear I’ll end up selling or trading it.
I suppose if one was to build a whimsy type pike or a layout depicting Model RR’s in the vintage sense or just a semi toy layout one might find use for Suydum kits but I agree with the post above, they are way dated, out of scale, thick and poor on detail and integrity of construction. I had some of the tin kits as well as cardstock/wood ones back in the mid seventies and as a teenager at the time I felt they were not of quality or appearance woth building/including on my layout and sold the completed kits off in some train swap meet. Sure they are classics but I view putting one on any layout I had anything to do with akin to using lifelike f units over intermountain ones…why would one want to ?
