I am in need of a second one fo these crossing kits… Or even better yet, two of an equivilent product with nickel-silver rails.
Does anyone know of where there is one, or do you have one lying around? The address from the manufacturer is “Spokane 12”, no ZIP code, so it must be pre-1963.
Does anyone know if a crossing kit was ever made like this with nickel-silver rail?
Draw the rail positions on a pine board, spike the rails down, file the joints to fit, solder it together.
If solder fills in the flange ways some, use a hack saw blade and a small file to clear it out. Then spike it in place on your layout.
My first layout was all TruScale wood roadbed track, some “ready Track” some from their kits - my Dad taught me how to build those kits at age 12-13, and a few years later the guys at the Severna park Club taught me to build turnouts from scratch.
BUT, why do you want that? With all the electrical problems of polarity with solid rail crossings? I have never had any issues with insulated crossings.
Henry, with DC it requires changing the polarity of the various “corners” of the diamond for each route to be used. Draw a picture, label the rails + and -, look for the short…
Here is a better picture of the crossing. You can see it is made in four solid metal sections at each frog. The only insulation is the 0.025" air gaps. This is the best way to make a cossing becuase there are no dead spots.
I tried hand laying track once, never again. I know what I am good at and I know what I need to farm out. Hire your defficiencies, and track building is mine.
The instructions show how to control it with a DPDT toggle, so a 4PDT toggle should be able to switch both at once. That might not work for what I want to do, I migth need an 8PDT, but they are available. I hate flipping multiple toggles.
The manufacturer seems to be Standard Models of Spokane, Washington.
That double crossing that Big Daddy posted looks perfect. I might check into that source as a supplier.
I remember those “Standard Models” crossings and they go way back, well Before the Oak Hill or Fasttracks templates (the list price of $2.25 tells you that!). When I see them at swap meets they tend to be in the grab bag boxes. That makes me wonder if they were an interesting idea that very few actually installed on a layout. Those guys inclined to cut the gaps to make them operable, lay the ties, spike the rails and so on were probably also able to make their own crossings.
If these truly can be found in “Grab Bag Boxes”, please pick one up for me.
If someone can mail me one, I will gladly send you STRATTON & GILLETTE boxcar number 12683 as a thank you.
Actually, it is not much of a thank you, I put the wrong decals on this one, so it does not match the rest of the 12500-13899 boxcar series. If it is the only SGRR car on your layout you will never know it is a goof.
Would you like me to give it a shot? Send me PM. If not interested, I’ll keep a look out at the Amherst Show in January. If it isnt there, it probably doesnt exist anymore.
I got my hands on an 8PDT switch. Actually, I found a 12PDT switch! I can use the extra contacts for signalling.
I found this beauty on eBay from a seller in Bulgaria. According to the description it is surplus from a Soviet Era piece of military radio equipment!
If you would have told me when I was in High School that I would be able to buy surplus Soviet hardware from someone in Bulgaria so I could wire a goofy solid metal crossing, well, that would have sounded nuts!
Somehow I came across a similar switch, also Russian Military surplus. I wired them to operate the turnouts on my double-slip switches. They are very versatile.
Originally they were make-before-break and I shortened the wiper and made them into break-before-make so they don’t short between positions.
A friend of mine had a clock that was supposedly made for Russian submarine service and I seem to recall ejector seats removed from MIG fighters being sold on the secondary market.
I can get you the whole Mig, you want the real thing, or a copy. How about a Spitfire, copy much cheaper or a bf-109. Tanks, no problem, steam engines, no problem.
