I have a can motor out of a new old stock HO unit. It never has run. The motor has a short of some sort, I guess. It shows Buehler and Kinston NC USA on the housing. It runs for a time on DC then stops, then runs (as something cools down I guess) and shows continual short when hooked up to DCC decoder. I suspect it is garbage. I have a rmotoring kit spare that I might make fit, though I thought I would ask. Never encountered this before. Lucky, I guess.
I guess Bühler motors are supposed to be one of the “top-of-the-line” motors. I probably had 2 dozen of them in various Stewart/Bowser locomotives. As I recall about four of them bit the dust. They would run fine for a few minutes, then bog down, current would go to about 2 amps and you could see sparks from the commutator, then after a minute or so, run OK. 20% failure rate!
I performed autopsies on them and could never find any cause for their failure. Some were newer with only an hour or so of running, others were much older. Still, the brushes, springs, commutators and windings all looked fine.
I just replaced them with other Bowser chassis, it was usually cheaper to find a complete chassis than the motor alone.
Kato, Genesis, BLI, Atlas, Life-Like/Walthers and the Stewart/Bowsers with Kato or newer non-Bühler motors have never given me any trouble.
Kinston is a town in NC where Buehler Motors was located. I believe they moved to the Raleigh Durham area. They make a variety of motors, but there website isn’t especially helpful.
Are you asking if one can DIY fix a can motor or are can motors replaceable? Of course it can be replaced and NWSL has tutorials on remotoring certain specific loco motors. However we can neither see your engine nor your replacement motor.
It is from a brand new old stock Stewart F unit…Fooled me by running on DC for several minutes. Did not realize it would later quit, and would not run at all on DCC. Of course, by the time I figured out it was not a bad decoder etc. It was late in the day.
Yes, I have a remotoring kit from NWSL that I have already found will probably fit. I take it a bad can motor is toast…I would think so, and not worth trying to repair. Onward and upward.
