Can grades be easily added to this layout in 101 Track Plans by Wescott?
Hi,
I’d like to run big locos in an 8X16’ room.
Layout design # 56, the
Dayton & Northern R.R. in Linn Wescott’s book, “101 Track Plans for Model Railroaders”
appeals except, I’m not sure if it’s possible to add inclines/grades to this layout or not?
Could anyone who has this book and is experienced offer some suggestions?
the radii of 32", 30" and 28" appeals for cab forwards, challengers, etc. in a small layout.
I’d have room for additional scenery on each side and ends.
I have 4’ I can add to the length and 2’ I could add to the width.
If there’s a way to add a decent grade and ideally a bridge and scenery or over under somewhere, I need suggestions.
This is one of several layout styles I’m considering. The number of operating sidings for industries appeals
as do the corssovers for meets on the double track, but I’d really like a couple of bridges somewhere…
Due to the doorway placements, I’m thinking a doughnut layout may provide me with the best design options and at least “imitate” some walkaround operating (sort of).
Thanks!
Are you a beginner getting ready to do your first layout? If so, I’d avoid inclines at all costs. Grades are the only places I have significant issues with derailing or uncoupling. And big engines are a nightmare on anything like a steep grade (more than 2%). At 2%, you need 175 horizontal inches (14.6 feet) to gain 3 1/2 inches of elevation (the minimum vertical separation for a lower level track). And you need that much to come back down again if you’re joining the ends of a loop.
I have to say that I’m not familiar with the layout in question. However, my feeling is that if you just want a bridge, you can use risers (either Woodland Scenics or make your own out of extruded foam panels) to elevate the track above the plywood (or whatever you’re using for a base) and just insert a bridge and water feature into your layout. The water feature would rest on the base, and thus be below the track.
This image shows the technique on my son’s layout.
Yes, I know the depth of field isn’t too good in the photograph, but that’s the idea. The lake is actually at a higher level and has a waterfall coming out of it, although it is still below the main terrain level.
Thanks CTV. Well not completely a beginner. I completed the benchwork and track work for a previous
5’X10’ by 16’ layout (The Big Panhandle/snap track layout) years ago in a cellar that later flooded annually! So I have some experience with grades and inclines. By saying I was a begginer (again) I meant that it’s been 18 yrs. since my last layout. Sorry, guess that wasn’t really clear…
Yes, going below the flat surface of the layout bench top is an option but I’d like to do a grade/incline.
Using your math I should be able to get one on one side (I came up with 14.6ft.) and back down the other. I have 16 ft. to work with… does that work?
This specific layout design (in the book) needs to be referred to directly I think. There are a number of double track crossovers, etc. that may mandate staying flat the whole way, but I’m hoping not.
Thanks for your pics. More food for thought if the grades won’t work out for the book’s plan.
Oh, by the way, my old Rivarossi Cab Forward climbed a 3.7% grade effortlessly on a friend’s layout the other day, so I think that aspect will be ok…
Capt, just calculate 2% of your available length. In other words, if the track length is 100 inches, 2% = 2 inches of elevation, etc. Two percent is sort of a rule of thumb which most equipment will handle just fine.
My HO layout has an over and under track loop and the entire layout is 3 feet x 4.5 feet, so obviously grades steeper than 2% are used. Mine are about 4-5% and all of my equipment will handle it just fine. Granted my trains aren’t more than 4 or 5 cars long, but on a layout as small as mine that’s about all that’s feasible anyway.
Just one bit of advice: Test it before you build it. Just get a long 1" x 4" board and temporarily tack or glue some track on it. Prop up one end on something and see how well your trains will run on it. It’s easy to try different percentages - just prop it up a little higher and try again. Then you’ll know for sure and it’s very quick and easy to do.
This plan has an oval mainline, so any increase in elevation will require a similar decrease within a relatively short distance… Not much will be gained by having track on a grade, and you don’t want a grade where there could be a cut of cars (or they will roll away). You might consider adding slight grades to the opposite ends, perhaps increasing elevation by a half inch or so.
The plan is quite crowded, but with the additional width and length that you have, there will be more room for scenery and a brook or two, with the corresponding need for bridges/trestles/culverts. Build the frame so that you have at least a couple or inches or so distance between the top of the framework and the (presumably plywood) track base, so there is room for below-tracks scenery without weakening the frame.
Mark
It’s not really the grades that kill you so much as the transitions. Unless they’re very gradual at the top, longer cars and locos will tend to derail. since the rear of the loco / car is still on the grade, which tends to make the front pop up and the flanges slide over the rails. This is much more of a problem if your transition is on a curve.
Going downwards, coupler trip pins tend to catch on ties if the transition is too abrupt.
And, of course, any transition is enough to uncouple cars if your couplers have a lot of play or aren’t perfectly aligned.
Speaking from experience in all three cases… I’ve found it relatively easy to gradually transition into a 2% grade… anything steeper gives me a kink in the track, usually at a joint, and that’s where the problems occur.
A technique I like is to raise the entire layout on foam. Then to do an over and under you split the length of your grades in half. You only need half the distance to go down into a valley and the other half to go up onto a ridge.
Capt.
I don’t have experience with that particular layout, but I wouldn’t take the layout plan as gospel. Those plans were drawn by graphic artists and only loosely represent reality. In addition, they used turnouts available 40 years ago and the ones today can have different geometry. I’ve had as much as 50% variation in size when I tried to recreate the plans in that book with software using the turnouts available today.
I’m not saying give up. I’m just saying maybe you should draw the plan out using one of the free programs available before you plop down your cash and find something ain’t right.
Hi, I wonder if the addition of a long grade will really add to this plan. Once the train gets to the top of the hill, what will it do in the extra 4ft you have available? It’d take more than that to turn around so it could come back down, unless the only real thing up there was another turntable. You’ll need a 3/4 circle plus a mean reverse curve there to reconnect with the original upgrade. In designing your grade, don’t forget to allow for the curvatures- both horizontal and vertical, to get onto and off the grade. While long-chassis locos look great on big layouts, they look (to me) a bit odd on tight radius curves and short straightaways, and love to lift wheels off the rails and drag couplers if the vertical transitions are too abrupt.
I’m currently building a variation of plan 62, with added staging at the bottom of the pictured plan, inside the raised level. Short bodied locos and back country railroading will be the rule. No-duckunder is important to me as well. My biggest challenge was to get a reasonable grade from upper right, going left and over the yard in a version that is a foot narrower than shown.
Glad to see someone else is exploring Linn’s great book, and really pleased to see it republished. There’s a lot of new thinking on layout design that could be applied to some of the plans in it.
Have fun, George
Thank you very much everyone! I figured with the cross-overs especially the ability to do a decent grade
was limited to impossible…:frowning:
George, I really liked plan # 62 as well. Oh, if only I had 12’ width in my room…
I’m glad this book is back too. It’s always been one of the better ones from the “old days”.
I had hoped that the 32" and 30" curves would’ve limited the friction on the sides of the flanges enough
to not “artificially” increase the climb of the grade, but I guess there won’t be enough length along the mainline(s) to accomplish something workable…
Well, if the same vein and a similar plan (but with more operation and only 26" into 24" curves) the following plan
has grades designed into it. If anyone also has this book in their libraries, I’d appreciate comments as to whether anything looks too optimistic with it. (Running articulated locos).
“Track Planning Ideas from Model Railroader” 58track plans from past issues selected by Bob Hayden
“The Warbeek and Sunmount R.R.” Pages 32 & 33
In some ways this layout appealed even more to me than the Wescott one, but I’d have to live with smaller curves.
Any comments, advice, etc. from anyone who specifically has this plan in front of them would be GREATLY appreciated.
PS: Thanks for your patience. I’m still trying to find which layout style and designs will fit and what I want
but thanks to all of the operations sessions I’ve started to attend, I’m getting a clearer idea.
I may ask for more help analyzing something completely different from these doughnut concepts, but
I think the “Warbeek” is along the lines of what I’d want so far. I’d still have room for adding a narrow
loco servicing yard or passenger terminal in the hallway later but it would have to be removed except for
operations sessions.
Thanks again guys,
Capt. G.
This design has some interesting ideas, but is unfortunately drawn a bit too optimistically to actually be built in the specified space, IMHO. It’s actually a little hard to tell because the illustration in the book is not to scale.
A few things that would be concerns for me. It’s listed as a 4% grade, but it doesn’t seem to allow for any transitions (if my estimated measurements are correct). And even at that, a couple of of the overhead clearances seem pretty tight for anything but pre-1950s equipment. So the actual grades will probably be steeper than 4% – pretty challenging.
Similarly, 2" track-to-track spacing combined with 24" & 26" curves may result in some sideswiping if you wanted to run full length (85’) passenger cars and an articulated engine with overhang. I’m not sure commercial turnouts will fit in some of the spots where there seems to be no space left for the actual turnout points. The aisle widths given around the outside are pretty tight and that duckunder into the center hole to operate the main yard and engine terminal will become tedious pretty quickly, I would think.
The graphic rendering is probably also a little optimistic in terms of the way it would actually look … there’s actually not much room for structures or scenery, unless your tastes run to retaining walls and vertical rock faces.
In short, it’s probably possible to come up with somethin
Thanks Byron. I was wondering if things looked too good to be true. It was already crowded but I really liked the (supposed) operational possibilities with runaround capability.
George, did you find Wescott’s drawings to be accurate and not too optimistic?>
Why or why, do the magazines even bother to publish these track plans without them being in scale/with an overlaid grid? I had some room to duck under from the side (2’ so I thought that might be managable if I raise the benchwork enough but of course it isn’t at all ideal.
My room/space is so frustrating. Two doors in the wrong
place, a wall that’ll need to be cut into, etc. It’s really wreaking havoc with any attempts at an around the walls layout so far (unless I go point to point without continuous running).
Do you think that this plan has enough operational elements to keep me and some experienced operators
interested for some time to come if I can base something more workable on it with local assistance?
If I must go with a doughnut shape do you think I’d be better off with the Wescott plan which is drawn to scale? I might be happy enough with the scenery undercutting/bridge suggestions the guys above made but I’ll have to think about it some more. I’d likely but a little curve or two in that mainline with the extra 4 ft. I’ve got…
I’ll be modeling 1930s through 1940s rolling stock. 36’-40’ cars and most likely 60’ (maybe 72’) passenger cars. I’ll have Mikados and Consolidateds (and small switchers) but I’d really like to run my Rivarossi Cab Forward and a potential Allegheny or Challenger if I can get them to look decent on whatever I end up with.
There seems to be a dearth of modern around the room (and other) designs for this small a space DRAWN TO SCALE.
Can anyone suggest anywhere to look other than the MR subscriber/online archives? I’ve been
looking and looking. As far as I’ve seen the MR online trackplans have no grids…
I’m trying
Hi again… About my layout: it started as 12x12’, but it was a foot too wide for the space available, so I shrunk it. Now it is only 11’w x 13.5’hi as the picture is printed with the pit opening on the right. After a ream of scratch paper and a lot of doodling, the orig plan kept coming back at me. Nothing says you have to slavishly copy the original, but I figured it to be a reasonable try. I made a 12"-scale HO drawing on a sheet of the heavy paper from inside a roll of sheet vinyl flooring that somehow survived my housebuilding, and drew in the switches as closely as possible. I used Peco mostly with a few Shinohara and some Atlas. I don’t think I had any problems getting things to fit. I use C100 except where the Atlas are, and they are on the conversion list for C100 too (presently C83) as some of my stock has deep flanges that hit bottom some places. I traced the dwg onto Velum and then onto the plywood subroadbed for cutting.
During construction it became very obvious that this rookie needed some place to hide/stage trains. That is something rare in 1950-70 plans. I got good space in the 2nd attempt by placing 4 runs plus the thru track under the hilands at the bottom of the sketch. Since I have access to all but 5’ at the top-left of the perimeter, I can reach everything so servicing isn’t a problem. There will be a couple of pop-ups to help with the reaching, one under the lumbermill to come.
You mentioned 1 loco; how much rolling stock do you have? In a small area, would N-scale be an idea for you? Unless this layout is for small fingers, that may be worth thinking about. You’d have roughly twice the real estate to build in, and only need about half the vertical clearances for flyovers. A helix might give you vertical space for a multi-level layout. In N, it would fit into your room easily; in HO, you’d have to think hard about it. They are rather large. In 8x16, don’t abandon the around the wall st
Hi George,
Yes, if I had any sense, I’d go with N scale, but not only do the tiny watch works like drivers on steam locos in that scale not “do it for me”, especially on rod drive Shays, (Diesels to look more than fine to me in N though…)
but my fingers are too big, my hands shake from spinal surgery years ago and after operating on a friend’s
very large N scale layout, I decided that scale just wasn’t for me. (No offense meant, perish the thought to
N scalers, honest! Some of my very best friends and operating sessions have and are non N scale layouts!)
But…I tend to break couplers and have trouble picking up adjacent rolling stock in yards, etc.
I need to at least pretend there’s some massive power thang goin’ on with the steam loco side bars and pistons and have a bit more “rumble”. It’s just a personal thing that I’m sure a lot of confirmed HO folks
can identify with. So I’m willing to go with less real estate on the pike for the personal joy of the nominally larger machinery and physical handling ease.
I’ve been online pricing pocket, accordian and bi-fold doors :slight_smile: I do have one that shouldn’t be too hard to
reverse it’s opening direction. It’s mostly the placement of the openings that’s giving me fits. I’ll contact
our local NMRA division guy and see what he can do with the space and advise…hopefully this week if he’s
returned from sunny Hawaii.
CHIP,
was the book you’re referring to (ala graphic artist’s renderings) the Wescott book or the other one?
I’m using Atlas Code 83 Mark 1V turnouts. Are they really that different in geometry from the ones in Wescott’s book? (40 yrs. ago?) That surprised me, but if so, I’m sure glad you mentioned it!
GEORGE, have you found the turnout measurements/geometry to be different for your plan, vs. the book?
Thanks again.
Yes, it was definitely the Wescott book.
I got serious about one of their shelf layouts. It was supposed to be 12" x 12’ if I remember. Using Atlas turnouts and flex, it took 18" x 14’ to get it all connected. I asked others here and was told it was common. Since then I’ve heard others say the same thing on other layout designs.
I’m not saying don’t do, just be wary. And I will add to what Byron is saying–those plans are very old style. We’ve come a long way since then. Track plans today look better and operate better for the same space. The biggest thing that has changed is that the designs have moved from being like amusement park rides to functioning railroads.
Because I was redefining the overall size of the plan, What I used for turnouts really became up to me. I bought a lot of curved units by Peco, Shinohara & Walthers, to the delight of my LHS. That large-radius curved one from Peco was a lifesaver, and inserted into an easement area was a boon! Think it is close to 60/30" radius. Laying everything out on that real-sized plan on the floor, meant I could put things where I wanted, and juggle track to fit. Track doesn’t need to come straight off the turnout, but can keep curving more to make a yard throat easier to line up. Some units have curved exits, while others straighten almost as soon as they get past the frog. Carefully trimming some back toward the frog can be useful, but leave enough space for the railjoiner… :+) I agree with the problems of small scale; someone keeps moving the world as I try to rerail cars! The Rix rerailer ramp is a great help.
Keep exploring. There’s no one way to make a layout; what works for you is your “right” way. Unless modelling an exact scene from the prototype, anything reasonable goes. The joy of freelancing means you can mix parts of several plans to your advantage.
G.
Yes, it would have been “game over” at the last operating session without the rerailer ramp. I carried that thing around in my breast pocket the whole session. (I needed it plenty too.)
This was a layout featured in this year’s January/Feb. issue of “N Scale” magazine. It’s the “Pilchuck Division” and I feel extemely fortunate to have been invited to operate on it!
I didn’t think about how much curvature one could use coming out of a switch. That might help, thanks.
I just posted a new thread asking for pics if possible of how people have disguised the oval nature of their ovals with view blocks and other tricks. IF I do a doughnut style layout, I’d normally curve the mainline a bit here and there, but due to Xovers and switches and relatively short run, that may not be possible.
Thanks for the encouragement.
Thanks Chip. Sorry it took me so long to get back to you, here. (The current lack of email notification thing
allows me to forget how many threads I’m participating in!)
Would you recommend taking a Wescott or Armstrong plan as the starting point still and just laying
it out on the floor/craft paper and make adjustments with current turnouts from there? (I’m not a computer/cad kind of guy). “I am not a CAD!” (sorry, couldn’t resist)…
If you have the book (which you seem to) would you comment on the operations potential of plan # 76
“Ouachita and Ozark R.R.?) This is the 2nd runner up although I don’t think I could make the curve radii
30” with this plan, do you?
Thanks so much for the comments and help!
EDIT: I just added the O&O R.R. plan question as a new thread, Chip so if you can offer insights please
do so there? Thanks for your generosity with everyone and for your primer on your site!
