Can I use Labelle 107 instead of Labelle 102?
I bought Labelle 106 and 107 but I didn’t buy Labelle 102.
You can probably use 107 instead of 102. Heck, I got away with nothing more than mineral oil applied with a toothpick for years; I only just started using real Labelle grease and oils. That said, if you do need an actual thicker oil, than mineral oil would probably work for you.
I bought the 102/106/107 3 pack. Per the instructions 102 is for exposed gears, 106 is for enclosed gears, 107 is lighter duty.
