I have a bottle of ‘‘same stuff’’ a little less then 1/4 , milky in color, that seams to have lost it’s ump. Been working with wood for quite a while so can’t remember how long its sat there. I don’t have a new bottle to compaire it to.
Is it possible that its contaminated with ? I would have thought it would just evaporate in stead. Or is there a problem persay with the material i’m trying to glue. What do you think ?
Every time you dip your brush in the solvent, you contaminate it a bit from the material you are working on, that being said you would end up with a solid at some point after enough evaporation but if it is still liquide it should still have some bite. I have my reservations about the same stuff being the same as pro-weld (going to miss that stuff), as it would work with more than styrene.
Micro Mark ‘Same Stuff’ is advertised as the same as Tenax 7R and Pro Weld. Considering yours is quite discolored, I would suspect it is contaminated. Both my Tenax 7R and Same Stuff are a clear-yellow in color I only use a Sable brush with a wood handle for plastic cement application. Artificial bristles may ‘melt’ in that stuff! Jim
