Ever since the new forum started I have been unable to log in except on my iPhone. I have tried three different PC 's running both windows 7 and 8 and every time it sends me to the search page or just clocks at a blank page until it times out and gives an “unable to connect” error. I have the same issue on the Trains forum. Something is not right. On the bright side with both the Kalmbach and Yahoo forums messed up I haven’t spent as much time on the forums.
Are you using IE 11? If so, go to the “compatibility view settings” option in the tools tab, and then add trains.com. It should work immediately.
Thanks! That worked.
