You have a couple of options. One is to figure out why your turnouts are not routing power, or providing power through the frog and beyond to the next set of tracks. It may be that the rail sides are dirty and need polishing between the sharp points rails that swing and the stock rails against which they are meant to snug up. In other words, it may be a problem of good contact. It turns out that the EZ-Track turnouts are historically problematic, and this is one area where they don’t do well…contact and lying snugly against their stock counterparts.
It would be a good idea to test your rail power throughout your turnouts with a meter…do you have a digital volt/ohm meter? It is almost essential in our hobby. You may find that the points don’t seem to have any power, but when you press them against the stock rails, the volt meter indicates new voltage!
An easy fix is probably to connect wire feeders to each of the rails in your yard. Just keep each wire oriented to the correct rails…you don’t want shorts.
Get a couple of the below meters. I have three of them. Get some double clip leads from Radio Shack also.
Some old timers use to use a ice pick type probe with a light bulb in the clear plastic handle and hook the power pack to the good track and probe for where the voltage is lost. Those can be found in auto parts stores.
Looking at your track plan, I would have 12 sets of feeder wires attached to the track – maybe more if you have it divided into blocks. I always put feeders on all tracks connecting to turnouts. This insure good contact, even if the movable rails don’t make contact.
I’ve had problems with Bachmann “N” pre-EZ track turnouts as well, pretty much requiring a change to Atlas. Other than confirming it’s the turnout itself and a loose joiner, you might try cleaning them as selector suggested, but the solution may have to be directly feeding both sides of each rail with terminal rail joiners or soldered feeds.
