Can't shut off sound on QSI equipped loco
I have a BLI 2-10-4 steam loco which has QSI sound in it.
I am using two NCE Pro Cab hand held corded throttles on my HO layout so far.
All the functions of the 2-10-4 work, except I can’t shut off the DCC sound when I pres “8” on my throttle.My other BLI QSI equipped locos work properly and the sound shuts off when I press “8”
This problem happens even when I use either Pro Cab throttle, so it’s not a bad NCE Pro Cab throttle.
I am kind of perplexed and think that perhaps I programmed something incorrectly?
You can program the amount of muting in CV51.1. First program CV49 =1 then set CV51 to anything from 0(full mute) to 63(50%of full volume) You can do this in ops mode on the mainline.
Pete
Thanks Pete !
I am still on a learning curve with CV’s etc
I’ll give it a try, thanks again!
TheK4Kid
That said, pressing 8 on the throttle should mute the sound, so something is still wrong.
