cell phone control vs mfg systems
There is some talk about operating a DCC layout using cell phones and the like as throttles. While I have experimented with this a little bit and am imressed with the convenience of it, I wonder how such a system compares with the use of the manfacturers equipment. Has anyone had the experience of such a comparison? Perhaps there is a published study I could read? Thank you. Old Fat Robert
The JMRI implementation of WiThrottle (uses Mac devices) is what I use. It basically overlays the existing wireless system on my NCE Power Pro. The WiThrottle uses the home WiFi system for its signal, while NCE has their own wireless node that supports the throttles. Once you get JMRI going, they’re seamless and don’t interfere with each other.
You get many more options with WiThrottle, as it can display all sorts of stuff with the Webserver that is part of the package, as well as control the turnouts that the NCE does via remote through their throttles.
The biggest difference between the two systems is price. A wireless DCC setup costs roughly $100 more than a wired system. The throttles are also more expensive, roughly $150 each. For the WiThrottle, the JMRI software is free and the full app is $10 at the App Store and covers the throttles app and the interface with the DCC system. You’ve already paid for your phone or, if you’re lucky like, me, get them as hand-me-downs from family, so cost is essentially zero, way cheaper than a DCC wirelss throttle no matter how you cut it.
I use JMRI Wireless throttles with a Digitrax system. In my case I am using the ‘Engine Driver’ App on my Samsung GS5 cell phone(free download). As a question, what does the full $10 App get one?
Why is it more convenient? Intuitively to me, it would be less convenient. It seems easier to me to just have the throttle kept with the layout, and put back into its holster when I leave the room.
What happens to the screen when I get or want to make a phone call when the train needs to slow down?
Ummmm, no. I still use one of those flip phone things that is used only for emergencies. So would not be “free” for me.
For whatever reason, the developer of the iPhone version, whcih is WiThrottle (the Android app is Engine Drive) decided to not make the app available for free. The free trial one can run a train but is otherwise feature limited, the full version does everything the Android version (a different programmer wrote the Android one) does.
You can get $10 (or less) Android phones from one of the pay as you go phone carriers, and they do not have any requirements that you must get a phone plane (and you don’t need one for this purpose). So you don’t even have to use the phone you use for calls, and it’s still cheaper than the specific manufacturer’s radio throttle. And there’s always old devices - I’m not one of those nuts who upgrades every time a new model phone comes out, I go at least 2 and usually 3 updates before getting a new device, and I still have the old ones. They can no longer make phone calls, they are not active on the carrie rnetwork, but they still connect to WiFi and the app runs just fine.
Randy is correct.
I use a retired Samsung Galaxy and two cheap 4-inch Android “Internet tablets” as wireless throttles with the (free) Engine Driver and (free) JMRI.
Total cost was less than the radio receiver alone for my DCC system,
$40 isn’t a bad investment for a 8" screen. And it’s certainly cheaper then a throttle. Even Lentz has gone completely this route instead of trying to invent a propriety handheld controller.
This all sounds good except for the cost of a computer for the train room to run the JMRI software.
Lots of ways to get around that because it doesn’t have to be the biggest, baddest compter around.
I’ve seen off-lease PC’s for well under $100 during the Black Friday/Cyber Monday season. Look in your local paper for private party ads and yard sales. Put the word out on your network of friends and relatives that the next time someone upgrades, you’d be happy to take their old machine off their hands. And so on…
Also, if you are a DIY’er, JMRI will run on a Raspberry Pi.
And some of the big online sellers have such machines as well, I know I’ve seen them on Newegg. Those $100 off lease machines aren’t even all that old and slow, most models are only 3-4 years old and MORE than powerful enough to run JMRI. You can probably get one for free if you check your local Freecycle.
And depending on what DCC system you have, you might just be able to use the one you have, if the connection supports running a long enough cable.
Small LCD monitors are super cheap - you can use an old cast off laptop, also probably can get one with a busted screen for free, just use the external display.
I used an off-lease $50 laptop till it died, now I just use my work laptop. Added advantage is that I have my panels to edit anywhere … Particularly good when setting up signal logic … Takes 15-20 min per signal head.
One issue with touchscreen throttles is that the slider is harder to use and I would really like the feel of a knob clicking through speed steps like on a Digitrax DT406 throttle. But- throwing turnouts is a problem on the Digitrax.
A pictorial depiction of the track plan on the screen is pretty awesome to mount on the fascia.
NP.
$35 Raspberry Pi will run debian based linux and Java which JMRI uses. It’s the size of a credit card. The only cavaet is you need to make sure your DCC->Computer interface chipset is supported on Debian. A good number are as all they are is RS232 Serial emulators.
http://www.alliedelec.com/raspberry-pi-raspberry-pi-2-model-b/70465426/
I REALLY NEED TO PUT TOGETHER A VIDEO to show you guys how to do this.
Unless you look at computers as a second hobby (not that is anything wrong with that), I can’t imagine going through all the work to get this set up. I just searched on Amazon for refurbished desktops under $100 and got 1,772 hits.
Some people will say they never want a computer in the layout room. I have to say, why not? My previous setup was such that my workbench was on one wall and my computer was on the wall behind it, so I could just turn aroudn and access the computer. That was not my main computer, it was a small low power one I built specifically for the layout. More often than not, I used it to look up information on something I was workign on at the bench, hugely handy to have there instead of either trying to use the tiny screen on my phone or actually going downstairs to use the main computer. I used it for stuff like that more often than controlling the layout, mainly because I never got so far that I had the whole layout operational. When I say I mada low power computer, it really was low power - both in actual AC power used to run it and processor power. I ran Linux on it because of that, but JMRI works fine with Linux. The downside is that I couldn;t use my Lokprogrammer to configure Loksound decoders, that software is Windows only. So when I re-set everything up in my new place, I will need to either build a new computer (just repalce the motherboard in thsi one, really) or attempt to get Windows to run on this one - it’s supposed to be able to, but I suspect it will be rather slow. One of those 3-4 year old cheap off-lease machines would be MUCH faster.
So you’ve had that thing since Miami Vice days and haven’t upgraded? Then your phone won’t run WiThrottle or the Android app, anyway, if you don’t have wifi support on the phone.
I don’t do cell phones at all, but my wife does. Most smartphones are a lot like computers, people upgrade them every so often. The old ones are, as Randy and other described, usable as throttles on wifi. Sure, they have some value, you can sell them various ways.
Me, with no phones at all? I just make sure to keep the honey-do list stays caught up and that seems to keep me supplied with all the throttles I need. YMMV.
Don,
Yes, please do a video on running JMRI on the Raspberry Pi. There are various instructions around, but they all seem to leave something out that the computer novice is likely to miss. I’ve managed to get the OS installed on the RPi, get JMRI on it, but still trying to get it to boot over the last few days. The wife has been helping when she can (she programs for a living) but not everyone can turn to good help when you get stuck on one of the many potential sticking points.
One thing that would be handy and maybe simpler, is to do a version that simply lets you click a desktop icon once you’ve remoted into a headless RPi. The boot-on-startup version that is making the rounds has its
I use Rocrail and my iPad and/or my iphone for throttle. All the buttons are marked for what they are on each loco, so I don’t just have meaningless F buttons. It’s got an emergency stop, and doesn’t look like a TV remote from 1980. And anyone with a smartphone can come by and get to the throttle from a browser if I give them my guest wifi password.
I think some of the replies in this thread assume everyone is used to physical throttle. I only recently got into model railroading, and never had any intention of going back to the Bad Old Days of wired throttles, badly labeled functions, and absurd mechanisms for changing DCC addresses.
Yes, I am purposely picking on Digitrax. One of their ugly, overpriced throttles would cost me more than what I’ve spent on my entire DCC system put together.
Also:
Because they don’t want more money left over to do train things. This is one of the reasons I didn’t join my local club. They wanted to spend money on buying separate pieces of hardware to do all the things a computer could do for cheap/free, just because they insisted that “It needs to run without a computer.”
Learning one piece of software to control many many things is far easier than learning each manufacturere’s specific piece of hardware that may or may not work with what you’ve already bought.
Indeed. There are signal controllers that can do all the logic without using a computer. Such as the ones made by Team Digital. But go ahead and read the instructions. Figuring out all those CVs to program the thing is WAY more complex than using JMRI’s simple signaling logic to define the “If block 2 is occupied, set signal 6 to red” stuff. But hey, to each his own. I’d rather have the single multi-purpose tool than six single-taskers.
Maybe back in the day when even a low end machine was $1000 or more (just remarked to a friend, there’s a new $5 Raspberry Pi model out, which has more computing power than a warehouse full of TRS-80 Model 1’s - when those came out they were $599 for the basic 4K RAM model. Yeah, 4K. You needed at least the $799 16K model to do any real stuff with. And that’s without the display. I always build my own computers, and I don;t spend $1000 on any of them, yet they are plenty capable of playing the latest games in high detail. 50% of the cost is that video card - so for a railroad computer, even to make a brand new one would far less. Not everyone can do that (well, if you can assemble more complex kits than BB or Accurail, honestly you COULD build a computer these days, there’s less electrical skill needed than for putting lights in a building), but that’s why those $100 off lease machines exist. More than powerful enough to do railroad stuff, plus surf the web and watch model railroad videos on.
Assuming the club is running DCC, you could really shake them up by telling them there’s tiny computer inside each of those black boxes…[:O]
Ooooh, nooooooo![(-D]
