I have been having difficulty finding Sculptamold in my area and have been told that Celluclay is a good substitute. Does anyone have any experience with Celluclay and it’s behavior in comparison to Sculptamold? I will appreciate any advice you can give. Thanks in advance.
Thanks Cacole. You saved me from a needless purchase. By the way, I’ve been following these forums and they are a really big help to beginners like me.
I don’t know about Celluclay but I’m having a hard time finding Sculptamold locally too. I found a product called Claycrete made by the same company at Hobby Lobby.(Amacco ?) It’s virtually identicle to Sculptamold. Looks and works the same and dries rock hard like SM. I can’t tell the differance.
I have not used Sculpamold, I understand ot had some plaster in it - maybe??
I have used Celluclay. The only problem I have had with it is slow drying time. It’s basically paste and finely shredded paper; you add water and mix. Drying is mostly by evaporation which can take days in a humid basement and a thick application. I have had mold start to grow during humid weather. The surface tends to be a bit rough, not a problem for scenery, but not so good for smooth surfaces like roads. Once it dries, it is hard and can be cut with a sharp hobby knife and sanded. It is Ok, but I prefer plaster or Durham’s Water Putty. I use it because a friend gave me a large bag of it.
I have used both products for several years. Sculptamold is hard and carvable. Celluclay as has been mentioned is a papery product, soft cutable, long drying time, if you work at it you can make it smooth out pretty nice. I use celluclay in locations where flexability is required, like on an access hatch cover. As noted previously it has a long dring time, and may grow mold. if spread thin and force dried, the surface may tear from drying faster. Most of my scenery is savogan’s wood putty. I buy it in the 50# barrell, stronger than plaster, a sort of yellow mud color, can be used in molds or carved. I have even made (simulated)cast concrete and stone buildings and bridges out of it.
