I have obtained an older Burlington Northern car that has what looks to be a caboose on the back half but on the front half is a large Spotlight! This unit is DC but I want to convert the Spotlight to DCC, running of an LED instead of the current DC light bulb ad maybe hide an on/off switch underneath! Can I use a stationary decoder on this car to make the light work and skip the switch? The DC contact swipes are still in the axles…
I use NCE’s light it decoders. You have to buy a minimum of 3. NCE also sells keep alive caps for them. I have 2 cabooses with the decoder and keep alive to run my rotory beacon on the cupola. I did a test and lifted the caboose off the track. The beacon kept going for a bout a minute. Joe
