ive been looking into instulation boards for my layout for a 2" base that will be on top of the ply wood and i saw that a 4x8 sheet costs about 27$ …i could fnd plywood cheaper and i was wondering if theres a cheapier way too get it i need about 3-4 sheets of 4x8…
Got to a few construction sites. They trim off and throw away gobs of the stuff. You probably won’t get any 4x8 sheets, but you’ll get enough little pieces to do what you need. And the best part,…it’s FREE!!!
Oh, and remember, if you’re doing rough “land” contours, you can fill the insides of hills and mountains with the cheap beaded type styrofoam. Just add a layer of the pink stuff over top to do your carving.
I have found bits beside the highway where it blew off trucks. I found about 6 sheets of 2" once. Recently I found some yellow stuff at a construction site. It seems to be the same though maybe just a little heavier. I found if you tell the foreman it is for a model railroad, you get more, if you listen to their story of when they were little and had model trains.
llol ill look around for it because i dont realy want to spend that much
Wow that’s funny. I totally forgot how much was wasted when they built the new library downtown Vamcouver. You could get a pickup truck of it every couple of days. And the garbage bins are loaded with it in any construction area there too. Just ask first though. Here you can get arrested for ‘stealing garbage’.
Stephen
